http://godisimaginary.com/video.htm
With which program can you easily create this but to still have a wide range of options?
Also is it possible to edit these movies so you can translate them to other languages, how would you do that?
I'm willing to learn..
Results 1 to 12 of 12
"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke
Any reasonable editor can do it - Premiere elements/Vegas Movie Studio/Ulead Video Studio. The stills can be done is Paint.net or the gimp or similar.
Changing the languages would be done most easily by using subtitles rather than trying to change the stills, although it could be done this way.Read my blog here.
I would like to completely adapt them to other language, both visually and with sound, so it doesn't have any subtitles and you couldn't tell a difference or ruin anything...can you tell me exactly the name of the best program to do this and version?
"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke -
There is no single program to do this. You would have to
Demux the video and audio
Record a new audio track in an audio program (audacity can do this)
Take snapshots of the still clips you want to change.
Alter them in a still image program.
Bring the new stills into a video editor (any previously listed can do this) and recreate any animations or transitions from the original
Edit all the clips back together with the original video clips, add the new audio and save the new versionRead my blog here.
yes, I was thinking along those lines.
So, can you just list me the best programs for each step you stated so that way I would know everything needed to be done and I would just have to learn how to use each program."The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke -
OK, thanks.
just one more thing, if I would be able to contact the author is it likely he would have some sort of template?"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke -
ah, sadly I can't find any way to contact..Originally Posted by guns1inger"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke
Most of the content actually comes from http://whywontgodhealamputees.com/
There is a contact pages here http://whywontgodhealamputees.com/god-contact.htm
Try the media@ address.Read my blog here.
I forgot to ask, what program would you use to actually create simple 2D animations but with wide variety of options?
Most of that was probably done in flash, although you could probably get away with power point if you had it. There are some cheaper 'flash' type programs you could look at as alternatives.
You could also do simple 2D work with paint.net (free) and your editor, but it would mean more work on your part.Read my blog here.
help about "Simple DVD Creator"
By vincy in forum Authoring (DVD)Replies: 1Last Post: 4th Feb 2012, 05:08 -
New "Simple Tricks and Nonsense" After Effects tips and tutorials webseries
By dastolidigital in forum EditingReplies: 1Last Post: 30th Jan 2012, 22:06 -
Batch create simple ("DirectShowSource") .AVS files?
By Asterra in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 00:46 -
WMV has no video on my TV out on "WMP v9 (VC-1 Simple/Main)"
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2008, 05:08 -
Codec for "Simple divx"
By tnam in forum DVD RippingReplies: 1Last Post: 7th Oct 2007, 23:04
