I have sony vegas movie studio platinum 8.0. Which is completely new to me.
I have four 42” flat that I will be broadcasting on. Resolution is 848x480.
The problem I’m having is taking the b roll footage and getting it to cover that area. I get a boarder on the left and right side. This continue to happen after going into the properties changing the project size to 848x480.
Any suggestions?
What are you playing back from ?
848 x 480 is effectively the resolution of 16:9 NTSC DVD on playback. If yu source aspect ratio is less than 1.778 : 1 then you will have to resize or crop to get rid of pillarboxing.
What is your source footage ? Is it 16:9 or 4:3 ?Read my blog here.
i believe i got it. not sure which is the best yet.
one is using the track motion to zoom in. another option is to un-check the Maintain aspect ratio, that or or changing the alpha channel to 1.2121 (video properties) -
chidoug -- hint
Normally you aquire and render to 720x480 DVD whether 4:3 or 16:9.
Then, when you play back the TV scales to 848x480 if that is your TV's native resolution.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Sony Vegas Pro - Importing clips from another project
By ClownInBrown in forum EditingReplies: 8Last Post: 18th Apr 2011, 19:43 -
First project sony vegas pro 10. Now first minute render corrupted
By sevenofone in forum EditingReplies: 1Last Post: 23rd Feb 2011, 21:57 -
Sony Vegas movie project 4:3 ratio but it need to be 16:9 wide
By Limpsy in forum EditingReplies: 14Last Post: 20th Feb 2011, 06:28 -
Sony vegas project
By samz in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 05:13 -
Sony Vegas 8 Rendering Project Question
By DJL82 in forum EditingReplies: 12Last Post: 30th Mar 2009, 23:54
