I was successful backing up all the other discs in the case, but Dangerous Days (Disc 2) after backup has menu tree issues.
The menu when selecting "play all" jumps to the trailers, and after "I Am Legend" plays dumps into the trailer menu page.
Selecting chapters, when attempting to play the first selection, you get the second documentary, with no access to the first program.
Decrypted with both DVDFab HD Decrypter (latest build) and DVD Decrypter in combination with DVD Shrink 3.2 and DVD Rebuilder (latest build), all delivered the same problem.
Thanks in advance!
Results 1 to 10 of 10
Since you tried almost all rippers (Rebuilder is not a ripper), looks like your problem is in messed up commands.
Only way to fix it is to correct (change) DVD navigation using PGCEdit (free) or DVD Remake (not free, but easier to learn). -
It's worth stating in case you or others don't know this, but RipIt4Me hasn't been updated in well over a year now. The creator got into legal trouble with somebody in the movie industry (may have been Macrovision but I'm not sure) and was forced to remove his program and stop working on it as part of settlement. It may work, but if not, that's just how it is.Originally Posted by RowMan
I have a suggestion - no harm in trying it. After shrinking to single layer size, open any of your VOB files (it doesn't matter which) in the shrunk directory with IFOEdit and select "Get VTS Sectors" and then answer OK to any prompts and then select Save. Then see if the menus behave correctly. -
For clarification:
I ripped the DVD once with DVD Decrypter, then once with DVDFab HD Decrypter. Each of those rips got treated to a shrink with DVD Shrink and DVD Rebuilder, resulting in 4 shrunk copies
DVD Decrypter -> DVD Shrink -> DVDR5
DVD Decrypter -> DVD Rebuilder -> DVDR5
DVDFab HD Decrypter -> DVD Shrink -> DVDR5
DVDFab HD Decrypter -> DVD Rebuilder -> DVDR5
All had the exact same menu tree issue as described above. -
I tried your suggestion, clicking yes at every prompt and saving with the suggested filename and type at the end. This resulted in "bad allocation" error when using Nero, so I could not burn the file. Possible I did something wrong with IfoEdit?
I have a suggestion - no harm in trying it. After shrinking to single layer size, open any of your VOB files (it doesn't matter which) in the shrunk directory with IFOEdit and select "Get VTS Sectors" and then answer OK to any prompts and then select Save. Then see if the menus behave correctly.[/quote] -
Backed-up this DVD last night using RipIt4Me, DVD Shrink, and ImgBurn. Resulting disc has no playback issues.
I don't get why Blade Runner is special - ok movie but a classic?
By yoda313 in forum Off topicReplies: 24Last Post: 28th Feb 2011, 16:36 -
Bangkok dangerous
By webmaster P in forum Newbie / General discussionsReplies: 22Last Post: 9th Jan 2009, 06:10 -
Bangkok Dangerous
By mikes01 in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 17:37 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 1st Aug 2008, 23:19 -
Is it dangerous to use offbrand mp3 speaker docks?
By yoda313 in forum Off topicReplies: 3Last Post: 21st Mar 2008, 09:22
