Actually, he didn't. I did. And yes, this thread was about the price of hardware and no discs are not hardware they are software. Remember, you do not own a movie you purchase, you own the right to watch it as you please, there is a bit of a difference. Your money pays for the movie, not the disc. Disc production cost is an irrelevant fraction, even on Blu-Ray now, of the price of the movie. Last I saw the replication cost is now less than $1 pr disc and dropping fast.Originally Posted by cracula
Results 121 to 150 of 240
Terje A. Bergesen
I find this to be quite an interesting statement, and I'd love for you to elaborate on it if you can. You see, I don't think this can be true. Given the following realities, how can one be better than the other?Originally Posted by sanlyn
- The two formats use the same encoding technologies, so all factors constant, they should have identical encoding.
- Given the identical encoding, hardware manufacturers use off-the-shelf components in the production of players, which means that the decoding chips in an HD DVD and a Blu-Ray player should be the same. In other words, the bit stream coming over the HDMI cable from an HD DVD and a Blu-Ray player should be identical.
- On a Blu-Ray disc there is some more space, and the format allows for a 30% higher bit rate. In theory this should mean that a Blu-Ray company should be able to squeeze a bit more picture or audio information into the bit stream. So far this has generally been given to audio. Not a surprise, the studios would encode the video for the lowest common denominator until the format war was over.
So, given that we today basically have identical encoding and identical decoding, how can HD DVD be better than Blu-Ray? Given a theoretical better encoding (more space and bandwidth) going forward, how does your statement make sense?Terje A. Bergesen -
A spec is a spec is a spec. If both formats claim 1080 capabilities using the same codec..so be it. I prefered the HD-DVD over my BD player simply because...
The HD is a finalized format. With BD I have had a variety of playback problems and freeze ups. So picture wise, granted..looks swell in both. More dependent regards picture quality is what proccessor is used. -
I'm sorry, but I think you need new glasses or new reading material. In the cases where studios published on both formats, they generally used the exact same video for the two formats. Given that the video is exactly the same, tha the decoder chip (which is off-the-shelf stuff) is exactly the same, then you have that the bitstream going over the HDMI cable to your TV is identical for the two formats. Stating that one of them has better image quality than the other in that case requires a monumental religious experience.Originally Posted by sanlyn
What color problems? The two formats use the same encoding, and once the bits move from your player to your TV, they are the same. No difference. How that color is represented on your TV is not a factor of either Blu or HD DVD. How can the "difference" between identical images be "easily distinguishable".Originally Posted by sanlyn
Based on what? So fare you are not making sense at a technical level. Your statements are in fact utterly absurd. You are claiming that there are vast differences between two items that are identical.Originally Posted by sanlyn
Well, right now we are looking at you saying that two technologies who produce identical visual results are vastly different in some respect. That is what I am trying to look into here. Ignoring that would be like ignoring a mountain dropped on my foot to look at my new shoes.[/quote]Originally Posted by sanlyn
But an identical visual experience from HD DVD would have been? That's absurd in the extreme.Originally Posted by sanlyn
No, it probably won't. Here is my prediction. Blu-Ray is the last and final disc-based format. Ever.Originally Posted by sanlyn
This is just sad. Are you blaming Blu-Ray for a bad encode? Are you really that clueless?Originally Posted by sanlynTerje A. Bergesen -
That's because you are sane and seeing. As long as the studios (the few that did) were releasing on both formats, given that both formats supported exactly the same encoding etc, they released identical products on the two. They would have continued to do so going forward, encoding for the space of the HD DVD and putting the same video content on both.Originally Posted by bbanderic
It would take a religious experience to tell the difference since there would have been none. The dude must be on some serious drugs swallowed with a phenomenal amount of Toshiba Cool Aid.Terje A. Bergesen -
Damn. You are FUNNY. Really. Clueless too, but funny. Yes, compressing movies will reduce their quality. Obviously. Just go watch a DVD on a decent sized display. Most of them look terrible even on my Oppo up-scaling player. Some just look bad.Originally Posted by sanlyn
Now, HD DVD and Blu-Ray uses the same compression technologies, and since we had two formats with different capacities and different bit rates, the studios that released for both formats used the one with the lowest capacity as the target. This meant that when they released they encoded the movie for HD DVD and they released this on both formats. That is, they put identical movies on their discs, leaving a good amount of spare capacity on Blu discs and not to forget, a good amount of spare bandwidth.
Since the format war is now over, the studios can encode (compress as you say) for the format with the higher capacity. That would be Blu. They can encode at higher bit rates given the higher bandwidth. Storage is almost irrelevant, both formats had enough storage for a good movie (but perhaps not for all the sound alternatives).
So, you are complaining that the more capable format won and you'd rather keep the less capable format since it is the less capable format that is the reason for the less than ideal quality of the Blu movies?
Would you like to share some of the drugs you are on with the rest of us? I can do with some good hallucinogenic stuff today.
I also find it astounding that you claim you want the best there is and then refuse HD quality. HD (both formats) are insanely better than VHS of any kind, or even professional Betacam. They are both also significantly better than DVD, not just in the higher resolution, but also in the color representation. HD color representation is a more significant improvement over DVD than was DVDs improvement over VHS.
Not only is HD and Blu-Ray a significant improvement over VHS/DVD, but in most cases Blu-Ray is also an improvement over film in theaters. The way film is printed and duplicated today means that the horizontal resolution that you catch in the theaters is about the same as you get on a big-screen TV at the appropriate viewing distance. Since film is reflective, given a good TV, Blu-Ray (or HD DVD for that matter) can give you a better viewing experience (but perhaps not social experience) than you get in the movie theater.
A good example is the movie "Pan's Labyrinth". This movie has been released in a variety of formats. In the theater, on DVD and on Blu-Ray. The best quality viewing experience for Pans Labyrinth you get from the Blu-Ray release. Both detail (resolution) and color is an improvement over the theater release.
So, why would you watch it on anything but Blu?Terje A. Bergesen -
Wow. You are a very interesting and curious person...Originally Posted by terjeber
Exactly as you've said: Reading is one thing, comprehension is another.Originally Posted by cracula
I'd suggest a bit further for you: first learn how to read, because you obviously can't distinguish between authors of a nested quotes in a posts longer than few words... and that's a basic online-reading skill, ya'know... -
I don't see the relevance of BD+ unless you're planning to rip and reproduce HD material.
Under such circumstances surely the complete absence of a HD-DVD burner is more of a more of a hindrance?Regards,
Rob -
I stand corrected. This online stuff is something i need more work at. Ahh the taste of humble pieOriginally Posted by DereX888
I fly and YOU SUCK! -
This is an excellent analysis, with the exception of this statement. BD (and HD-DVD) have ALREADY been cracked. Any person with some internet knowledge can find all kinds of BD/HD-DVD hi-def quality material from various places on the internet (I won't say where) to acquire for their own collection even as we speak.Originally Posted by orsetto
That is distressing to know.Originally Posted by jagabo
I wonder how many (all?) Blu-Ray discs have BD+ ... in other words do all have it or only some or what?
Also I don't understand how you can rip it to your computer for playback but then can't do nothing with it? Can you re-encode it or ... ???
A handful at most. The only one I've come across is The Simpson's Movie.Originally Posted by FulciLives
I've managed to rip and re-encode everything else.Regards,
Rob -
How long do you think it will be before the situation is reversed?Originally Posted by rhegedus
I don't know. It may not be.
Every copy protection measure has been broken to date. I don't see many studios willing to pay royalties for a feature that may be worthless in a few months.Regards,
Rob -
My, my, the BluRay boys are not only a bit color blind, but they get snippy about any criticism of their very imperfect new toy.Originally Posted by terjeber
If everything about the two technologies is "identical" (even tho you've gone to the trouble of pointing out how they are different), and you can't see any differences between the two (even though you've taken the trouble to point out the differences that cause you to favor one over the other), then why does it matter to you that I don't like Blu-Ray? You mean you really bought and kept an Oppo player? So your insensitivity to midtone and shadow density loss doesn't bother you, and neither does your inability to see the Mediatek decoder's problem with cyan? A number of people have noticed these problems, one of them even had the nerve to post a scathing one-star review on Amazon, of all places, against Sony's Blu-Ray players! Kinda made me feel a little better, tho, to see that I wasn't the only viewer who noticed that so many Blu-Ray discs and players just wouldn't let an image bloom naturally. But, then, most BluRay people seem overly involved with numbers rather than concepts that are more difficult to define.
Spend your money, then, and enjoy. I returned my Oppo player a week ago (my wife thought the Oppo's image looked grimy, and my neighhbor complained it was too green), and brought my Sony BluRay back to its roost at BestBuy, and both because I didn't like the color, and didn't like the lack of snap or brilliance in the image, and didn't like all the artifacts. There are plenty of opposing views about the technology, its implentation, and the players used. Many are posted here and elsewhere. Many people, besides me, didn't buy BluRay for any of several reasons. For one thing, I still don't see many high-end a/v shops carrying Blu-Ray (or HD-DVD for that matter), but they're selling $2500 SD players all day long. Believe it or not (you probably don't), but many video hobbyists agree with me and disagree with you. It seems there are likes and dislikes on both sides, and plenty of posts and documentation to justify both.
Uh, after looking over your post and the information therein, I wouldn't use the word "clueless" quite so freely when referring to those with whom you disagree.Last edited by sanlyn; 20th Mar 2014 at 10:33.
Ha ha.Originally Posted by jagabo
But CSS encryption has been circumvented, so why the concern about BD+?Regards,
Rob -
Given that Blu-ray now has a monopoly on high def discs and that AACS has been totally cracked, there will be a lot of pressure on movie studios to use BD+. I suspect virtually all new Blu-ray releases will use BD+.Originally Posted by rhegedus
BD+ will be cracked as well, we all know that, just like all the copy-protection schemes that came before it. This concern about BD+ or anything like it is a non-issue, it's only something for the Blu-ray haters to talk about, for now.Originally Posted by jagabo
I've been away for awhile and have just read all of these comments with some amusement - it really gets hot aorund here!. With respect to BD movies outselling HD-DVD, everyone seems to miss the obvious reason: most movies were exclusive to BD. As a father of 2 little girls, I can assure you that they want their Disney movies - which are available exclusively on BD - same for Spider-Man, etc. It was just a matter of time before HD-DVD died - they simply did not have the movies (read: studio support) available that the public wanted.Originally Posted by terjeber
Pure and simple: HD-DVD was outsold and died because they did not have the movie studios onboard like BD did. Anyone who thinks otherwise needs their head examined. -
I think that sums up the argument, maldb, and makes moot any debate about which format is/was "better". I'm glad I didn't sink anything into either format. As it is, word is out that any Blu-Ray stuff you buy today is obsolete even as price gouging on BD is already underway.Originally Posted by maldb
It isn't difficult being king of the hill when there's no competition.Last edited by sanlyn; 20th Mar 2014 at 10:34.
Price gouging?
I just bought I am Legend for $18.95. The two-disc Special Edition SD is $22.99.Regards,
Rob -
...Now the Oppos are junk too? The Oppos which are WIDELY regarded by video enthusiasts everywhere as having some of the best DVD players on the market.
I'm really starting to think that your problem isn't with Blu-ray or Oppo DVD players at all, maybe you need to learn how to calibrate your set to get the most out of your players. Better yet, maybe you should stay away from digital all together and stick with your VHS and vinyl record players. From your comments on this thread nothing digital seems to make you happy. -
Yes, but that's just a matter of time.Originally Posted by jagabo
Probably no one pissed enough, or persistant enough, haven't faced this obstacle yet.
Few years later someone reading old posts such as this one will be laughing at us
Not exactly.Originally Posted by sanlyn
Unlike any previous 'format wars' this time it was not the consumer(s) who decided and chose one over another, but the corporations.
S*ny in particular have learned its lesson from Beta failure, and they acted and responded this time better (for them).
Lengthy "market war" would have cost them way more than pulling the strings it holds in the movie business and paying off the competition now, thus effectively ending the 'war' before both side were financially involved in it too deep with no way out.
Fortunately for S*ny, HD-DVD wasn't "to be or not to be" for their competition, and the competition didn't have any influence in the movie business at all (unlike S*ny), because from hardware point I can bet that probably the standalone HD-DVD players were outselling standalone BR-DVD players at any given moment in time of their competition. -
But in the tiny minds of studio execs the fact that BD+ hasn't yet been cracked looms large. They will demand it for all new releases.Originally Posted by DereX888
That's why I added:Originally Posted by jagabo
Few years later someone reading old posts such as this one will be laughing at us smile.gif -
I've seen some very bad HD conversions, as I stated before people are not concern about a more sharper, artifact driven image that some here speak about. The quality of a few Blu-ray movies leave much to be desired if you are concerned about quality. Why pay more for less?
The average Joe does not care about HD.Do unto others....with a vengeance!
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 23:04 -
Netflix To Raise Prices On Blu-ray
By MOVIEGEEK in forum Latest Video NewsReplies: 1Last Post: 31st Mar 2009, 06:38 -
Backing Up Death Race Blu-Ray
By mr.adventure in forum Blu-ray RippingReplies: 26Last Post: 14th Jan 2009, 11:18 -
Blu-Ray Player Prices coming down
By tmw in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Nov 2008, 11:18 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
