I'm looking for a PC card that will allow me to capture/input HDMI or Component inputs. I know of the Blackmagic cards, but what other options exist???
Shuttle SH55-J2-BK-V1 w/4.00gb Ram, INTEL i3-550, 3.2ghz, WIN7 home premium 64bit
hauppauge 950q, 1600, 1250 -
I'm in Oz and may be on wrong track with your query but I capture SD and HD TV here in OZ (we have PAL system) with the TV antenna cable plugged in the back of the card and my Compro tuner card will capture everything and does it beautifully.
The card is the Compro Videomate T300 now superseded by similar Compro cards. I highly recommend this brand of tuner card. If in USA you would need NTSC support but I believe the Compros support both NTSC and PAL automatically.
I have the TV antenna cable plugged into my HD TV tuner near my TV and a bypass antenna cable running from the back of the TV tuner to the Compro tuner card. The HD TV tuner does nothing to that bypass signal before the Compro captures the signal, the SD and HD tuners are in the Compro card.
The T300 also has Composite in and S-video in which you can use with an appropriate adapter cable but the TV antenna bypass cable is the best way to go.
Check if you TV tuner has an antenna bypass.
Not sure what else you would want to connect to the PC capture card.
Hope this helps. Compro has a USA web site. -
What's wrong with the Intensity Pro?Originally Posted by pglenn
Both BlackMagic and AJA have a full line of more expensive cards with analog components or SDI input.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I dont need a tuner - I already have both SD and HD tuners. I just want to be able to input an HD video from another source and record it. I know the Blackmagic are supposed to be good, just looking for other options for comparison. I'd like to see if there is something comparable for cheaper as I probably wont be using the card too often.
None that I know of for HD to HD. For HD to SD see the HAVA line of products. For SD 480i component see the latest ADS Pyro.
Hauppauge has a new product coming that is supposed to take tuner HD in and hardware compress to h.264 MPeg.Recommends: Kiva.org - Loans that change lives.
Curious to know what format the input HD video stream is.
If your HD PC tuner will capture this format all you need is converter cables to match your card tuner inputs.
TV in USA is in NTSC format.
Capturing Video from external source on a Hauppauge HVR-1800 card
By blueleo65 in forum Capturing and VCRReplies: 6Last Post: 14th May 2012, 17:54 -
Capturing VHS video to Win TV card ?
By mister benn in forum Capturing and VCRReplies: 9Last Post: 31st Jul 2011, 14:25 -
Does capturing from an HDTV source mean i'm getting HD video?
By snafubaby in forum Capturing and VCRReplies: 8Last Post: 2nd Jan 2011, 11:24 -
Need help in choosing a video capturing card - Matrox
By avinash.rao in forum Capturing and VCRReplies: 0Last Post: 1st Aug 2008, 07:49 -
Build-in or separate video card for TV and capturing
By DeafBug in forum ComputerReplies: 3Last Post: 16th May 2007, 16:03
