I am trying to restore a commercial VHS tape. The original source is film that has been telecined and transfered to tape. The film has been edited after the telecine process (i.e. trailers added, etc) so I am afraid that IVTC is not possible. I will be deinterlacing before encoding with xvid.
There are two types of artifacts that I am concerned with removing/lessening:
1. VHS drop-outs (horizontal scratches/lines) due to tape degradation.
2. Film spots that were not removed during digitization and transfer to vhs.
I would like to use AviSynth and Fizick's DeScratch and DeSpot filters respectively for each of these issues. I am familiar with AviSynth but find the shear number of parms for both plugins intimidating. Help from any script guru's would be much appreciated. Suggestions for a starting point with parms?
This might turn into an interesting thread. :o)
I have just finished doing the same thing. There was no great solution. I found a couple of acceptable ones.
I think the original movie (1942) was Cinemascopic in 'TECHNICOLOR'.
A Republic Pictures Studio movie. Trailers added 40 years later and then put on VHS.
I finally settled for this:-
AviSource("movie.avi", audio=false).assumefps(25,1,true)
#remove VHS rubbish from the bottom
crop(0,0,0,-8).addborders(0,4,0,4)
ConverttoYV12()
DeGrainMedian(limitY=5 ,limitUV=5, mode=4, norow=true)
ReduceFlicker(strength=3)
There WILL be further posts. -
The problem I have is that I either get too much interpolation overall, or interpolation in areas that are not "true" spots. I just can't seem to tune parms correctly. I am also concerned with filter order. Considering the following order:
Descratch
Deinterlace
Despot -
I understand correctly, dropouts are usually 'white -horizontal- streaks' that run across
the image at random places, though they can be at or near that same place depending
on the condition of the tape/vcr. And if this is the case then it might be possible for
someone to write an avisynth script to detect/lock onto these and rub them out.
Posting a few examples of the artifacts might help further..
-vhelp 4561 -
IMHO Fizicks Filters (Descratch & Despot) will not give you good results until you IVTC back to the original progressive film source. TIVTC worked well for me.
Could you not split the source into the original and trailers and process each individually?
8mm film to dvd and which video transfer system to use
By krlorenz in forum RestorationReplies: 16Last Post: 28th Jul 2014, 17:12 -
Question on VHS Capture vs DV Transfer to PC
By VideoTechMan in forum Capturing and VCRReplies: 36Last Post: 3rd May 2012, 06:57 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 17:14 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
What I want to do: Transfer/capture old VHS and Hi8 family tapes.
By Boomer1948 in forum Capturing and VCRReplies: 7Last Post: 4th Jan 2008, 23:19
