Edit: I figured my question was maybe not that clear.
What I'm trying to do:
Create a script that will take small clips of different video and put them togeter to make a beat. The clips need to be between 0.25 second and 2 seconds. I need to use FFMPEG in a linux environement, in command line onl
The problem:
If I put clip that are not a fraction of 0.5s it's usualy end being offsync pretty quickly.
Hypothetical solution:
Compile the video and the sound seperately, then put them toggeter and stretch the sound to make it fit with the video.
Question:
1. Which format should I use to compile the videos... and for the sounds?
2. Also, is there a way to stretch the sound to make it fit with the video?
3. Anyone think this solution is simply stupid?
	What make you hapiii?
	It sounds like an editing project that would likely be more straightforward with a proper video editor in a Windows environment. Adobe Premiere, for example. Google is your Friend
	Sounds like you are making this as difficult as possible. I know it can be done using avisynth for the trimming and ffmpeg for the encoding under windows. However I have never seen the advantage to editing with avisynth. Personally I think you are making a simple task needlessly difficult. I would be interested to hear why you want to take this approach.I need to use FFMPEG in a linux environement, in command line onl (sic)Read my blog here.
  Putting Together Movie ClipsBy SeaBird in forum EditingReplies: 1Last Post: 24th Mar 2012, 12:31
  how to make a dvd with lot of small video files?By sumeshkri in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2010, 11:13
  Small MPeg clips From CamBy vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jan 2008, 15:28
  How to create small clips from a movie!By unstopabl3 in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 05:34
  Help putting together my small business.By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 24th Sep 2007, 18:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
