hello,
im want to make a dvd with more hours than usual, i did some filterin with plugins i know but i guess they only work when u start with a bad source but no when u want to compress a perfect shape one
i was wonderin if u could recommend some avisynth plugins to push the hours when dealin with dvdrip sources, some for toon and others for normal footage would be nice
excellent if u could add some startin settings but with names only ill be fine, i can research how to fit them to my need
thanks a lot n saluts
Just encode with a lower bitrate. How many hours do you want to put on a DVD? The quality decreases along with the bitrate.
You can also try 1/2 D1 format if you want to put more video on a DVD. Look to 'WHAT IS' DVD to the upper left on this page for that and the DVD specifications, format and structure. You have to adhere to that if you want it to play back on a set top player. -
Originally Posted by noob4ever
thanks im gonna try it, any more suggestions? im tryn to encode something like 950avg bit
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 18:00 -
Recommendation for Video compression courses
By andrewbutkus in forum Newbie / General discussionsReplies: 0Last Post: 11th Sep 2010, 09:12 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 11:32 -
Need a recommendation
By berfles in forum Authoring (DVD)Replies: 1Last Post: 4th Jul 2007, 02:21 -
DVD Compression/Shrink Software Recommendation?
By Noy2014 in forum DVD RippingReplies: 7Last Post: 13th Jun 2007, 06:12
