Hi, Chrissy, its been a while since me last posted. I like your program alot and it was well worth the money. I have a problem with an avi file I converted to a dvd with your program. The video mpeg4 and the audio mp3 KHZ 128 KPS. When the conversion is finished the video is perfect,its the audio for some strange reason on playback its really loud and destorted.
I checked original avi and the audio is fine any ideas why this is happening?
I have a suggestion is the any chance in future, 29 frames fps and also 23.976 fps meaning less jerky video NSTC to PAL 25fps. I would be greatful for any help.
Closed Thread
Post your log from this run.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Here is the log, video is perfect just the audio is to loud and disorted.
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.3600.0
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.57 MB
Executable size in bytes: 2703443
Executable CreationTime: 09/12/2007 17:41:26
Executable LastWriteTime: 07/02/2008 23:17:04
Executable LastAccessTime: 05/03/2008 10:08:05
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="05/03/2008 10:14:00" Filename="NONE">
<AssetSet>
<Asset ID="ee351eec-a976-409d-937e-9092792257f3" Path="D:\New Folder (2)\[DVDrip XviD MP3][MercifulRelease]" Filename="Brothers Grimm [DVDrip XviD MP3][MercifulRelease].avi" />
</AssetSet>
<DVDStructure>
<TitleSet Name="PLAY" PostCmd="" MenuButtonType="0">
<MenuButton X1="336" Y1="483" X2="431" Y2="529" FontFamily="Monotype Corsiva" FontSize="26.25" FontStyle="2">PLAY</MenuButton>
<Title Name="Brothers Grimm [DVDrip XviD MP3][MercifulRelease].avi" AssetID="ee351eec-a976-409d-937e-9092792257f3" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-256" Highlight="-256" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Documents and Settings\anthony\Desktop\New Folder (2)\brothers_grimm_ver7.bmp" AudioPath="C:\Documents and Settings\anthony\Desktop\New Folder (2)\b" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="" InitialDVDFolder="" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 701 MB
file=D:\\New Folder (2)\\ [DVDrip XviD MP3][MercifulRelease]\\ [DVDrip XviD MP3][MercifulRelease].avi
FormatName=avi
Num_Frames=170443
DurationInSecs=6817
Duration=01:53:37.7
VideoCodec=mpeg4
VideoFFSTNum=0
Width=640
Height=360
Standard=PAL
BitRate=862
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x1]
Audio1SampleRate=44100
Audio1Codec=mp3
Audio1BitRate=128
Audio1Channels=2
AVI2MPG: 4872kbs Full-D1
10:14:00: Looking for AVI PAR...
Pass 1/1: Processing Brothers Grimm [DVDrip XviD MP3][MercifulRelease].avi
10:14:04: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
10:14:04: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
10:14:04: libavutil version: 49.1.0
10:14:04: libavcodec version: 51.27.0
10:14:04: libavformat version: 51.12.1
10:14:04: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
10:14:04: Input #0, avi, from 'D:\New Folder (2)\Brothers Grimm [DVDrip XviD MP3][MercifulRelease]\Brothers Grimm [DVDrip XviD MP3][MercifulRelease].avi':
10:14:04: Duration: 01:53:37.7, start: 0.000000, bitrate: 862 kb/s
10:14:04: Stream #0.0: Video: mpeg4, yuv420p, 640x360, 25.00 fps(r)
10:14:04: Output #0, dvd, to 'D:\New Folder (2)\Brothers Grimm [DVDrip XviD MP3][MercifulRelease]\Brothers Grimm [DVDrip XviD MP3][MercifulRelease]_S2D.mpg':
10:14:04: Stream #0.0: Video: mpeg2video, yuv420p, 720x576, q=1-31, 4872 kb/s, 25.00 fps(c)
10:14:04: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
10:14:04: Stream mapping:
10:14:04: Stream #0.0 -> #0.0
10:14:04: Stream #0.1 -> #0.1
10:14:04: Press [q] to stop encoding
10:14:04: mdb:511, lastbuf:0 skiping granule 0
10:14:04: mdb:511, lastbuf:0 skiping granule 1
10:14:04: mdb:511, lastbuf:380 skiping granule 0
10:14:04: mdb:511, lastbuf:380 skiping granule 1
10:14:19: [dvd @ 0084E46C]buffer underflow
13:27:54: video:4046733kB audio:372841kB global headers:0kB muxing overhead 2.158810%
13:27:54: AVI2MPG: done.
13:27:55: Done: Processing assets for DVD creation
Authoring DVD Folders
13:27:56: Creating TitleSet # 1
13:27:56: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
13:27:56: -->: DVDFolders creating VTS
13:27:56: -->: VTS 01
13:27:56:
DVD Folders: Processing C:\Program Files\BadgerIT\SVCD2DVD v2.5\dummymenuPAL.mpg...
13:27:56:
DVD Folders: Processing D:\New Folder (2)\[DVDrip XviD MP3][MercifulRelease]\[DVDrip XviD MP3][MercifulRelease]_S2D.mpg...
13:33:29:
13:33:29:
13:36:41:
13:36:41: Finalising DVD...
13:36:41: Encoding menu...
---------------------------- ENCODING MENU ----------------------------
TV Standard: PAL
Aspect Ratio: 4:3
Image size: 768x576
Resize size: 720x576
13:36:46: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
13:36:46: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
13:36:46: libavutil version: 49.1.0
13:36:46: libavcodec version: 51.27.0
13:36:46: libavformat version: 51.12.1
13:36:46: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
13:36:46: Input #0, wav, from 'C:\\Documents and Settings\\\\Desktop\\New Folder (2)\\b':
13:36:46: Duration: 00:00:22.4, start: 0.000000, bitrate: 1411 kb/s
13:36:46: Output #0, mp2, to 'C:\\Documents and Settings\\\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.3600.0\\menu\\menu.mp2':
13:36:46: Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
13:36:46: Stream mapping:
13:36:46: Stream #0.0 -> #0.0
13:36:46: Press [q] to stop encoding
13:36:46: size= 312kB time=11.4 bitrate= 224.0kbits/s
13:36:46: size= 557kB time=20.4 bitrate= 224.0kbits/s
13:36:46: size= 612kB time=22.4 bitrate= 224.0kbits/s
13:36:46: video:0kB audio:612kB global headers:0kB muxing overhead 0.000000%
13:36:48: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
13:36:48: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
13:36:48: libavutil version: 49.1.0
13:36:48: libavcodec version: 51.27.0
13:36:48: libavformat version: 51.12.1
13:36:48: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
13:36:48: Input #0, image2, from 'C:\\Documents and Settings\\\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.3600.0\\menu\\background1.jpg':
13:36:48: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
13:36:48: Stream #0.0: Video: mjpeg, yuvj420p, 720x576, 25.00 fps(r)
13:36:48: Output #0, rawvideo, to 'C:\\Documents and Settings\\\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.3600.0\\menu\\backgroundES.mpv':
13:36:48: Stream #0.0: Video: mpeg2video, yuv420p, 720x576, q=2-31, 1000 kb/s, 25.00 fps(c)
13:36:48: Stream mapping:
13:36:48: Stream #0.0 -> #0.0
13:36:48: Press [q] to stop encoding
13:36:50: video:112kB audio:0kB global headers:0kB muxing overhead 0.000000%
13:36:50: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
13:36:50: INFO: [???] File C:\Documents and Settings\anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\backgroundES.mpv looks like an MPEG Video stream.
13:36:50: INFO: [???] File C:\Documents and Settings\anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\menu.mp2 looks like an MPEG Audio stream.
13:36:51: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
13:36:51: INFO: [???] Found 1 audio streams and 1 video streams
13:36:51: INFO: [???] Selecting dvdauthor DVD output profile
13:36:51: INFO: [???] Multiplexing video program stream!
13:36:51: INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\backgroundES.mpv)
13:36:51: INFO: [???] VIDEO STREAM: e0
13:36:51: INFO: [???] Frame width : 720
13:36:51: INFO: [???] Frame height : 576
13:36:51: INFO: [???] Aspect ratio : 4:3 display
13:36:51: INFO: [???] Picture rate : 25.000 frames/sec
13:36:51: INFO: [???] Bit rate : 1000000 bits/sec
13:36:51: INFO: [???] Vbv buffer size : 126976 bytes
13:36:51: INFO: [???] CSPF : 0
13:36:51: INFO: [???] Scanning for header info: Audio stream c0 (C:\Documents and Settings\\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\menu.mp2)
13:36:51: INFO: [???] MPEG AUDIO STREAM: c0
13:36:51: INFO: [???] Audio version : 1.0
13:36:51: INFO: [???] Layer : 2
13:36:51: INFO: [???] CRC checksums : no
13:36:51: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
13:36:51: INFO: [???] Frequency : 48000 Hz
13:36:51: INFO: [???] Mode : 0 stereo
13:36:51: INFO: [???] Mode extension : 0
13:36:51: INFO: [???] Copyright bit : 0 no copyright
13:36:51: INFO: [???] Original/Copy : 1 original
13:36:51: INFO: [???] Emphasis : 0 none
13:36:51: INFO: [???] SYSTEMS/PROGRAM stream:
13:36:51: INFO: [???] rough-guess multiplexed stream data rate : 1255800
13:36:51: INFO: [???] target data-rate specified : 10080000
13:36:51: INFO: [???] Setting specified specified data rate: 10080000
13:36:51: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16619
13:36:51: INFO: [???] New sequence commences...
13:36:51: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
13:36:51: INFO: [???] Audio c0: buf= 0 frame=000000 sector=00000000
13:36:51: INFO: [???] STREAM e0 completed @ frame 11.
13:36:51: INFO: [???] STREAM c0 completed @ frame 932.
13:36:51: INFO: [???] Multiplex completion at SCR=2021376.
13:36:51: INFO: [???] Video e0: buf= 0 frame=196612 sector=00000048
13:36:51: INFO: [???] Audio c0: buf= 2688 frame=000932 sector=00000311
13:36:51: INFO: [???] VIDEO_STATISTICS: e0
13:36:51: INFO: [???] Video Stream length: 114879 bytes
13:36:51: INFO: [???] Sequence headers: 2
13:36:51: INFO: [???] Sequence ends : 0
13:36:51: INFO: [???] No. Pictures : 12
13:36:51: INFO: [???] No. Groups : 2
13:36:51: INFO: [???] No. I Frames : 2 avg. size 15532 bytes
13:36:51: INFO: [???] No. P Frames : 11 avg. size 5865 bytes
13:36:51: INFO: [???] No. B Frames : 0 avg. size 0 bytes
13:36:51: INFO: [???] Average bit-rate : 1767200 bits/sec
13:36:51: INFO: [???] Peak bit-rate : 1592800 bits/sec
13:36:51: INFO: [???] BUFFERING stream too short for useful statistics
13:36:51: INFO: [???] AUDIO_STATISTICS: c0
13:36:51: INFO: [???] Audio stream length 626976 bytes.
13:36:51: INFO: [???] Syncwords : 933
13:36:51: INFO: [???] Frames : 933 padded
13:36:51: INFO: [???] Frames : 0 unpadded
13:36:51: INFO: [???] BUFFERING min 15 Buf max 683
13:36:51: INFO: [???] MUX STATUS: no under-runs detected.
create sub file....done.
running menu muxer....13:36:53: MUXRATE =4400
13:36:53: after read_bmp(): xd=720 yd=576 x0=0 y0=0
13:36:53: Found EOF in .sub file.
13:36:53: warning, sub on line 0 starts before 4s, (some players won't show it)
13:36:53: subtitle duration: -1
13:36:53: ***************** HERE WE GO EVE.ODD *******************
13:36:53: MenuType: EVEN
13:36:53: subtitle_packet_size: 446
13:36:53: subtitle_packet_size & 1: 0
13:36:53: subtitle_packet_size mod 2: 0
13:36:53: MenuType==""
13:36:53: MenuType=="EVEN"
13:36:53: final subtitle_packet_size: 446
13:36:53: max_sub_size=446
13:36:53: subtitle inserted at: 0.184656 sd=0
13:36:53: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
done.
13:36:53: Encoding menu...Done.
13:36:53: SVCD2DVD: DVDfolders
13:36:53: -->: DVDFolders creating table of contents
13:36:53: scanning D:\New Folder\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
13:36:53: -->: Creating menu for TOC
13:36:53:
DVD Folders: Processing C:\Documents and Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\menu.mpg...
13:36:53:
13:36:53:
13:36:53: Finalising DVD...Done
13:36:53: Done: Authoring DVD Folders
Considering your source, you should expect problems. I believe the forum rules prohibit me from helping you further with this.
Dwight
- Herm Albright
svcd2dvd no audio
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 1st Mar 2010, 08:58 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Problems using SVCD2DVD converted assets in DVDLab
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2008, 16:28 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 09:35 -
SVCD2DVD 2.5 Problems
By mistalcote in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Aug 2007, 03:31
