Hello everyone. This is my first time here, so hopefully i'm not beating a dead horse with this question. I downloaded mac the ripper for my new macbook (I am used to using dvd shrink for PC)..neways, I got a hold of Into The Wild which was a great movie by the way..neways, I figured i'd try to backing it up...I did the "extract main feature only" and the file is over 7 gigs...shouldn't the program compress the movie to fit on one dvd? Since this is my first time using it, I was wondering if anyone knows what I am doing wrong...or if anyone can give me some advice since I am new to Mac..
Results 1 to 18 of 18
MTR doesn't do shrinking, it just rips.
To make your VIDEO_TS folder smaller,
you'll need a different app,
like Toast, Popcorn, DVD2OneX, etc. -
That's why it isn't called MacTheShrinker.
It does only what its name suggests -- it rips. Period.
In anticipation of your next question, there are no freeware GUI shrink tools on the Mac. Ffmpegx (shareware) does have a barebones shrink tool, and costs the least of anything out there. -
hmm...ok...
Case, you said toast shrinks the video ts file? I just got toast 8 titanium. I dragged the file into toast, tried to burn it, and once the disc was full THEN it told me it wouldn't be sufficient...but prior to burning it, it said the disc capacity wasn't full...so how do I shrink with toast? -
Set Toast to Video > VIDEO_TS folder. Drag your VIDEO_TS folder to the window. Set the 'Fit-to-DVD video compression' checkbox.
(Screenshot) -
awesome..i'll give a shot...thanks so much...
so basically, the video ts folder is the main folder on a dvd?...what does it contain besides the audio and video...are the menus and extras in there as well? -
If you look to the left of this page, you'll see a whole bunch of useful links. If you click on "what is DVD," you'll be led to a page that tells you a great deal about the structure of the files on a DVD. The short answer is yes, the video_ts folder is the one that contains "everything" related to the movie proper.
cool..i'll check it out..
case..you said something about just using mac the ripper to rip it and toast to burn and shrink....i did that..it worked on one dvd, and not the other...get it to to work with the "other" dvd, I ripped with mac the ripper, shrunk with dvd2one and then burned with toast...that worked...i read somewhere that you have to do it that way...rap with mac the ripper, shrink with dvd2one, and then burn with toast...is this true? It seemed to be for that one dvd I did the other day..i kept getting errors when i tried shrinking and burning with toast.. -
Al Bloom
one thing i'm noticing....if I simply rip the movie with mac the ripper and drag it into toast, it says there's usually a 50 percent reduction in quality...but when I use mac the ripper, then dvd2one, then drop it into toast, it says the quality has only been reduced by 5 to 10 percent...is that accurate?
I think DVD2OneX (DTOX) does a better job of compressing than Toast. It's 3 steps instead of 2 (MacTheRipper rip/ DTOX compress/ Toast burn) but the results are better so I think it's worth the trouble. I get a lot of macroblocks with Toast's compression.Originally Posted by 91rtstealth
I also like DTOX for joining mulitple titles (or chapters) for burning using Toast's Video Mode. You can also burn from DTOX but I don't think it makes any menus.
So yes DTOX comes in handy all the time. -
Yes Popcorn does some of what Toast does, although Popcorn 3 has a feature or 2 not in Toast 8. I understand those features will be included in Toast 9 which is coming out on April 1st (no fooling
https://forum.videohelp.com/topic335954.html -
cool cool..looks like i'm good shape now...thanks for all the help guys
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Mac The Ripper Help
By fugly in forum MacReplies: 5Last Post: 17th Nov 2008, 08:35 -
Latest solution in ripping and shrinking DVDs?
By SirDracula in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2008, 15:25 -
Ripping & Shrinking DVD's in Mac OS X?
By devilcoelhodog in forum MacReplies: 14Last Post: 8th Jun 2008, 00:31 -
Mac the Ripper help
By spunkyc in forum MacReplies: 6Last Post: 12th Dec 2007, 20:25
