Hi, I have a CCTV system and have it output-ed with a BNC cable. I bought a BNC to Composite cable changer and inserted the Composite cable to the TV card but when I open the capture steam with VLC or the program that my TV card came with (TV@Anywhere) I get a blank screen. I was wondering if anyone had any ideas.
Thank you in advance for your help.
	Do you have a male BNC to male RCA 1/4" cable or one of the small adapters that connects at the BNC terminal? I have had nothing but problems with the small adapters over the years and always use a cable:
 http://www.bhphotovideo.com/c/shop/4166/Video_Cables_BNC_to_RCA_Cables_Composite_Component_.html
 BTW: The BNC is outputing an analog composite signal, just uses a different connector. BNC never made it to consumer gear because manufacturers felt that consumers would have more difficulty with connections over the RCA plug. The BNC connectors lock on and are more robust in terms of accidental disconnects, making them ideal in professional or commercial set-ups...thus why your CCTV system uses them. Best to go BNC at the camera end and convert to RCA at the computer end. Don't convert the BNC to RCA.
	actually I think I have a BNC Male to RCA Male Composite Cable, would that change anything?
	It should work. Connect it to a TV (rca end) to see if the camera is working. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	dosen't the end that meets the camera have to be femaleOriginally Posted by qwertymk
 http://www.dvrsecuritylab.com/images/D/security-camera-hd-550-d2.jpg
	BNC has a male pin but a female like shell. The pin is what countsOriginally Posted by loster
  Recommends: Kiva.org - Loans that change lives. Recommends: Kiva.org - Loans that change lives.
	Did you tried using that same cable to connect to a "video in" jack on a TV? You can only use the process of elimination to figure out which is giving you the problem (the cable, CCTV system, TV card). I would try a different cable first (since it is the cheapest).
 http://www.dvrsecuritylab.com/home-security-systems/12-ft-bnc-to-rca-cctv-surveillance-cable.html
  Same cable for BNC, SDI and Composite?By kayut in forum Off topicReplies: 2Last Post: 31st Oct 2011, 10:37
  female BNC -> 6pin Mini DINBy nkordyjaka in forum Capturing and VCRReplies: 5Last Post: 27th Apr 2011, 09:56
  DVR card BNC Female to regular cable (rg60) conversionBy johnnyfly123 in forum Capturing and VCRReplies: 1Last Post: 27th Mar 2010, 16:49
  FML VGA to FML 2 3 pin XLR, L R Rca Audio, Composite BNC, S-video BreakoutBy silverlage in forum Capturing and VCRReplies: 1Last Post: 12th Dec 2008, 12:07
  Does simultaneous computer usage affect capture quality w/USB capture?By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
