Hi all,
What i want to do is add two episodes of a tv series and put them onto one dvd. In the dvd maker part of mpeg video wizard there is an option to add video files into the dvd menu. Basically what i want to do is have 2 movies (or in my case two episodes) with chapters on a dvd. But i noticed that the add video files option is blanked out when i try to add video file to the dvd maker project. Does anyone have any ideas how i can make this possible by having two movies (or two episodes from a tv series) on one dvd?
thanks
I am not familiar with that program. If you want two shows on one DVD you normally would have two tracts, A main or title menu, and two tract menus.
Can you find "add another tract"? If so use that function and then add the 2nd video to it. -
thanks smokiestover i think i got it now
What i have to do is edit it first (take out commercials etc) then once finished editing i have to export the now edited vobs into a stream copy mpeg, then load next episode do the same thing then export to stream copy into an mpeg file..then i add the two streamed mpegs into the dvd maker and then i can create chapters if i want and have two episodes..is this correct? can anyone with mpeg video wizard confirm this is the right procedure?
thanks -
I use Mpeg Video Wizard DVD and that one let you import VOB's or Mpeg, edit and export DVD. I guess with Mpeg Video Wizard your procedure is correct.
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 03:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
Working with VOB Files in Womble MPEG Video Wizard
By toscano in forum DVD RippingReplies: 2Last Post: 29th Jan 2009, 13:33 -
Womble video wizard mpeg dvd
By Remyisme in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 14:47 -
settings for Womble MPEG Video Wizard DVD
By Vril-ya in forum EditingReplies: 0Last Post: 20th May 2008, 19:18
