i have avi's with mp3 audio format. after authoring the dvd and playing it via dvd player, the audio just screeches like in a high pitch. when i go to simulate the dvd in TDA 3, the audio is turns out be a chipmunk voice with bad static -- basically the audiio is being played very, very, very, fast.
i would very much like to correct this, and author it properly. is there an audio encoder that i need?
my settings were set to "automatic (smart rendering prioritize)," then i later changed that to "linear pcm," and "dolby digital." after making the change in audio settings, i simulated the dvd and nothing has changed. i think i'm missing something, either that or the avi audio format is incompatible with TDA 3.
your assistance is much appreciated. tia.
				Results 1 to 1 of 1
  Assistance with audio sync issues (and general cleaning)By DB83 in forum AudioReplies: 2Last Post: 8th Oct 2008, 08:31
  Garbled Audio in Nero Dvd project - Video is fine - need assistance pleaseBy RossChurchill in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2008, 16:44
  Assistance with Capture settingsBy kiwiusa in forum RestorationReplies: 0Last Post: 14th Jan 2008, 19:41
  TDA DVD SettingsBy marioval in forum Authoring (DVD)Replies: 1Last Post: 28th Dec 2007, 07:08
  reauthoring TDA video in TDA throws audio offBy spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
