Hello
I was wondering whether it is possible to change the Text assigned to a Menu Button without re-authoring the whole DVD. I understand that the DVD needs to be ripped to the HDD, and that I have done. But then I could not figure out how to change the texts.
If possible, please let me know how.
Thank you.
আমি বাংলায় গান গাই
Read my blog here.
Yeah, I'm not exactly sure which he means either. However, if you're changing the text of a still menu, then my guide may be of use:
https://forum.videohelp.com/topic313743.html#1606732
If it's the Subpic that needs to be edited, then open the menu in DVDSubEdit, export the Subpic in question (File->First assign an editing app in Preferences->followed by Edit Subpic Bitmap with external tool) , and then reimport it (File->Replace current subpic with BMP file). The editing part for both processes is up to you. -
Thanks...
I shall go through the guide manono posted and post the feedback here.
What I want to do is this: Say the button has a text assigned as "Play". I would like to change the word "Play" to something else keeping every other things just the same. So The button will function the same only it will be known as something else but "play".আমি বাংলায় গান গাই
Dvd reauthoring
By Psco2007 in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2011, 12:41 -
GFD Software, How to customly put text in button
By volam in forum Authoring (VCD/SVCD)Replies: 1Last Post: 11th Nov 2008, 09:53 -
dvd reauthoring
By sumeshkri in forum Authoring (DVD)Replies: 3Last Post: 30th Nov 2007, 23:05 -
Chapter button pop-up text description in GFD?
By awesomer in forum Authoring (DVD)Replies: 6Last Post: 18th Nov 2007, 19:21 -
Changing aspect ratio (reauthoring DVD)
By Turbo Sensonic in forum Authoring (DVD)Replies: 38Last Post: 12th Aug 2007, 18:17
