Hello,
I have several hundred WMV video files with bad embedded author/title/date information that I am about to convert to MP4 for use on an iPod using MediaCoder.
However, the correct information is correctly encoded in the file name.. i.e. "title-author-date.wmv"
So, two questions:
1) Can I set MediaCoder to extract the tags from the file name?
2) Failing that, is there command-line program I can use to clear the MP4 metadata and add my own? (I'm willing to write a Python script to automate it, if needed.)
-- Thank you
mp4tags.exeis there command-line program I can use to clear the MP4 metadata and add my own?
Code:mp4tags: You must specify at least one MP4 file. usage mp4tags OPTION... FILE... Adds or modifies iTunes-compatible tags on MP4 files. -h, -help Display this help text and exit -v, -version Display version information and exit -A, -album STR Set the album title -a, -artist STR Set the artist information -b, -tempo NUM Set the tempo (beats per minute) -c, -comment STR Set a general comment -d, -disk NUM Set the disk number -D, -disks NUM Set the number of disks -g, -genre STR Set the genre name -G, -grouping STR Set the grouping name -P, -picture PTH Set the picture as a .png -s, -song STR Set the song title -t, -track NUM Set the track number -T, -tracks NUM Set the number of tracks -w, -writer STR Set the composer information -y, -year NUM Set the year -r, -remove STR Remove tags by code (e.g. "-r cs" removes the comment and song tags) -
Wow. That looks great. Where can I download the mp4tags.exe program?Originally Posted by Midzuki
Thank you.
How to add tags to a video file in windows 7?
By Rudyard in forum ComputerReplies: 0Last Post: 8th Jan 2011, 18:29 -
Metadata for MP4 in WMP
By tommiy in forum Video ConversionReplies: 0Last Post: 6th Nov 2010, 16:48 -
make mxf and add custom metadata
By zimbot in forum Video ConversionReplies: 0Last Post: 7th Jul 2010, 07:00 -
MKV Tags/MetaData
By blazerqb11 in forum Video ConversionReplies: 0Last Post: 18th Feb 2010, 18:35 -
Edit MP4 frame size metadata
By tb582 in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 22:13
