Hi.
I'm trying to put some subtitles onto an avi. Iv'e tried with Virtualdubmod and I get the error -2 message, and in GK I get an 'attempted to request an YV12 frame that wasnt mod2 in width and height' message.
s there any way I can force either programme to work? Or is there a programme thatll rejig my avi so its the right width and height?
Thanks in advance
Chirufan
Results 1 to 22 of 22
Resize the frame to multiples of 2 (even better, 16), both width and height. For example 576x432 is very good, 579x432 won't work.
Right. How do I do that, lol??
Do I have to download a certain program or can I do it in virtualdub or GK?
CHirufan.
EDIT FOund the resize filter in VDM thanks. -
ah, one morer question - does resizing it take a long time - its giving me a projected time of three days to do it.
Chirufan -
Three days sound a bit too long yes.
. But if you have a old computer, using 2-pass encoding and is encoding a 5 hours video clip it could take that long.
What video codec are you using? under video->compression.
How long is the video clip?
And do you have a "slow" computer? Under CPU under your Profile have you listed don't know. -
Ah yeah, I have an athlon 64 53500+.
Im using divx 5.2.1 codec, standard encoding, 1-pass, and the avi is 6 mins long, 10meg in size. the ave bitrate is 780 kbps if that helps. the only filter Im using is the resize one (from 320x239 to 320x240) and at full processing.
Chirufan -
That whould be super fast! I suspect you mean 3500+ though. Or maybe 5400+.Originally Posted by chirufan
The resize filter in VirtualDub is pretty fast. The settings you gave should encode pretty quickly. My computer is faster than yours (Core 2 Duo, 2.4 GHz) but using only the resize filter with a 320x240 source resized to 320x244, and Divx at 6.8 its "balanced" setting, a 10 minute video would take about a minute to encode. Even in "Insane" mode it would only take about 3 minutes.Originally Posted by chirufan
Divx 6.x is faster than Divx 5.x, but not the huge amount you are seeing. Try pressing the Restore Defaults button on the Divx Codec Properties dialog. This will reset the codec in case you accidentally made some changes that might have caused the massive slowdown. See if that makes any difference.
Try reencoding using Fast Recompress mode. No filtering is done in that mode but it will help you determine if the slowness you are seeing is in the resizing (and related processing) or the compressing.
The problem could also be something about your source file. Do you see the same slowness when using a different source? -
I tried to re-encode it by just choosing 'save as' without using any filters, and choosing fast recompress, and it gave me an error message 'video format negotiation failed: use slo-repack or full mode'
Just in case I'm doing something wrong, Ill list everything I can find out about whatIm tryinfg to do with VirtualDubMod.
I'm using VirtualDubMod 1.5.10.2
I want to put an SSA subtitle file onto the avi. I made the sub file in URUSofts subtitle workshop.
The avi is 10.4mb, and its size (given to me by the filter message in VDB is 320x239. When I choose 'resize', it suggests 320x240 as the closest neghbour. I've been choosing that.
The avi plays fine in realplayer, btw.
When I load the avi into VDB, I get the 'VBR audio stream detected' error message, and it asks me if I want it to re-write the header. I say NO.
I have chosen divx as the compression. in the configuration menu for divx that comes up if I choose 'configure', the default settings are:
Home theatre profile, standard encode performance, avg bitrape of 780kbps, 1-pass encoding and a max bitrate of 6951.2.
When I choose defaults and click OK I get an additional screen telling me Im also using bi-directional encoding (B-frames) for smalelr file sizes from the trial version of DivX Pro (I have 15 days left on this trial).
In the Options drop down menu, preview input and output and sync to audio are ticked.
OK, so when I choose 'subtitler' as the filter, I get the error-2 code. So Im trying to resize it. Same setup as above described, but using 'resize' as the only filter - from 320x239 to 320x240
I accept that and choose 'save as'
avi, full processing, video frames per segment limited to 100, segment size limited to 60meg.
Save, and it starts encoding. thread priority is normal. Its been encoding about a minute now, and the estimated time remaining is 1hr 20mins and counting...up. lol.
Theres one green pip of the progress bar.
Projected file size is 24254k
video rendering is 0.0fps
I have subbed a few similar avis in the recent past without problem, but none of those needed resizing.
Anything else I can provide? Any ideas?
Chirufan -
Is the "Current video frame" counter (top line) incrementing? Very slowly?Originally Posted by chirufan
Try a different codec. Uncompressed, just as a test. -
current video frame increments to 42/8044 and then stops there. I tried it three times, same figures.
Uncompressed test (with the resize filter on) gets the same result. it goes to 42/8044 and sticks.
WHat does that mean? and what do I do next?
Chirufan.
ps thanks for all your help, all, btw. -
I tried subbing with another avi. 4 mins long, 9,5meg, works fine in realplayer. Didnt get an error message as its already 240x320. Same thing happened with the current video frame couinter. . stopped at 42/7399
Can you try encoding without the subtitler? Does it stall at frame 42 as well?
(Just trying to narrow down what is causing the problem) -
yep, encoding with no filters on using divx stalls at frame 42 as well.
All your tests indicate that VirtualDub is having trouble reading your source file. After opening the file select Video -> Scan Video Stream For Errors. See if it gets through the file. Try just playing the file with the >I (preview input) button, or File -> Preview Input.
I scanned the video stream for errors - no errors reported.
Playing both the avis with Preview Input, they get to frame 41 and freeze.
Trying to encode with XviD Mpeg 4 codec and no filters gets me 'cannot start video compression. An unknown error ovvurred (may be corrupt data) (error code-100) -
RIght. I just tried to sub a vid that successfully subbed 2 weeks ago, using the same process, avi and .ssa file. it also stalls at frame 42.
I also got the VBR error message at the start with this, but I cant remember now if I was getting that with the earlier, successfull subs.
Maybe I should just try to uninstall VirtualDubMod etc , re-install it and see if it works? -
Well, I downloaded VirtualDub again, and I still get the same problem. This is driving me crazy. Is there another program I can use to put hard subs onto an avi?
Chirufan -
I've uninstalled everything virtualdubmod, GL, all my codecs etc) and re downlaoded them and set it all up, and the avis are still stalling at frame 42. I tried with a few other avis and they work. SO I guess its the avis that are the problem. is there any way I can force Virtual dyubmod to ignore that frame 42?
Success! In the end I deleted the avis and transferred them again to my pc. they work now, proving that it was thwe avis that were at fault, not my codecs or virtualdubmod
Thanks very much for all the help, though.. nice helpful forum, this.
Chirufan
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 07:30 -
Frame size 1920x1080 is not supported
By ljCharlie in forum Newbie / General discussionsReplies: 10Last Post: 1st May 2008, 11:22 -
Help Friend! How to read subtitle file on my dvd player (not divx supported
By justin1983 in forum SubtitleReplies: 17Last Post: 26th Jan 2008, 11:42 -
Is there a list of supported resolutions for DivX certified DVD players?
By quitearush in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 05:26 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 11:07
