I made a movie through Adobe Premiere a while back and have the following question---it is now VOB files on a DVD. I need to make it into a file that I can e-mail to a potential employer and have them open and view it---any suggestions?
Most E-mail attachments are limited to much less than 50MB, usually <10MB, so any conversion you do will look terrible. I'd convert the video to Xvid with AutoGK, then upload the AVI to Vimeo.com, which will make a very high quality "youtube" style video that they can watch. Just send them the link
Example video:
http://www.vimeo.com/325709 -
That is a VERY odd requirement for you to email them a file. Unless your video is very short, you run the risk that your file will be too large to email or it will be blocked by the recipient as possibly being spam as a lot of spam filters limit attachments. Take a segment of the film, say 5 minutes, and convert it to another format. You could reduce the resolution and use MPEG-1 at low bit rates (352x340 at 2000 Kbps or less). Everyone should be able to play MPEG-1 with no problem. You could also convert to Flash or QuickTime with the understanding that these might be problems on some non-PC and non-Mac machines. Again, note that larger file sizes may be blocked, so even 5 minutes may be too big to email and you may need to cut it down to 1 minute. Anyone who would ask you to email a file to them without any further instructions is an idiot - keep that in mind.
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 06:06 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 19:21
