This is a basic question, I know. I have a nice hard drive to record shows, but I don't know what I need to buy and hook up to it to transfer them to DVD. I guess it's a burner, but I'm a newbie at this, obviously. Thanks![]()
Results 1 to 11 of 11
In what format are those shows?
You need a dvd writer and a dvd conversion/authoring software like simple tools like convertxtodvd, dvd flick or if you want more advanced dvd menus tda, nerovision, ulead dvd workshop. -
It depends of what you want as a final format. You can just burn them as DVD data discs if you just want playback on the PC. ImgBurn or most any burning program can do that. Yes, you will need a DVD burner. But they cost less the $30US most times, so not a big expense.
Or you could convert them to DVD. ConvertXToDVD is one simple program for that. Freeware, try FAVC. Use ImgBurn to burn.
Or you could convert them the Xvid/Divx with a program like AutoGK. There are quite a few set top Divx players available.
Lots of other methods and formats, depending on what you want to do. -
I just want to transfer shows/movies on the hard drive to DVD-R. I'm not sure I am answering the question you are asking. I want to be able to play them on a regular DVD player. I don't care about putting menus on it.
Then you want ConvertXtoDVD($50) or DVD Flick(free) or FAVC(free). Those create dvd-video that works on regular dvd players.
I didn't think I needed a software program. I want to hook up a burner (I guess) to my DVD recorder (with built in hard drive) and transfer stuff off of it to DVD. Isn't that the easiest way? What do I need? Thanks
Do you have standalone hdd recorder with shows? Or the shows on your computer hdd?
You need blank DVDs that are compatible with your standalone and a little time to read the manual that came with it.
Does the OP have a standalone DVD recorder (with an hdd and a DVD read-write drive in the same unit) or does he in fact have a DVR (hdd only)? Because of some of the questions he asked, it sounds to me like there is a small chance that there is no DVD drive in his recording device, and he is calling it by the wrong name.
If he had a DVR not a DVD recorder, then I would recommend he search the forums regarding that topic and learn what he can from other threads before asking more questions. If he has a DVD recorder, then telling him to read the manual is about all I could advise as well. If he needs advice on which brand of DVD to buy, Verbatim tends to be compatible with more DVD burners than other brands, although Taiyo Yuden is also very good. -
With the info they gave it's hard to tell what it is. If they read the manual and give us more info we can help them out. Until then all we can do is guess.
I have some VHS tapes that I want to transfer to a computer hard drive.
By marada in forum Capturing and VCRReplies: 15Last Post: 30th Nov 2009, 09:35 -
Sony AVCHD transfer to computer hard drive
By jal79 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd Jul 2009, 15:21 -
Can I transfer my direct tv dvr movies to a hard drive?
By Vityaz in forum DVB / IPTVReplies: 11Last Post: 23rd Jun 2009, 17:54 -
Liteon 5045 Hard Drive Recoring Transfer
By allibg5 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 25th Feb 2009, 15:43 -
Transfer miniDV to hard drive. Does it matter what software is used?
By vid83 in forum Newbie / General discussionsReplies: 9Last Post: 11th Dec 2007, 20:08
