I know you can crop each video one by one, but is there a way to crop multiple video streams at once all at the same crop size? or do I have to export the video and combine them all first, and then crop the one video?
Visit http://www.cgaming.com for 720p and 480p Game Videos from the Xbox 360 and Wii
This would still be cropping them all individually, but you could save the crop size as a preset, and then apply it to each video. It would take far less time than setting all the crop settings manually each time.
You could use a Cookie Cutter on the Video Bus track...
Regards,
George -
For various projects, I've used all three methods mentioned above...George's "cookie cutter" solution is the "quickest & dirtiest" one, which, of course, I like.
Depending on other factors (added effects, envelopes, etc.), any of the three methods will work for you...as always, balance out the quality/filesize/rendering time factors to find the best method for your purposes.
Stiiv
cant open sony vegas pro 11 'event pan/crop'
By kitsuneee in forum EditingReplies: 7Last Post: 4th Apr 2013, 22:11 -
Sony Vegas Movie Studio 9 Platinum: Event pan/crop keyframing problem
By Dude E. O'Loo in forum EditingReplies: 2Last Post: 22nd Jan 2012, 19:09 -
Sony Vegas Pro 8 ... transitions application on multiple video clips ???
By holeepassion in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2010, 01:04 -
Cant open the pan/crop window in sony vegas 8.0 pro
By Anonymous5494 in forum EditingReplies: 2Last Post: 28th Jun 2009, 02:25 -
Sony Vegas multiple on-screen videos
By Pilotwings_64 in forum EditingReplies: 10Last Post: 24th Mar 2008, 21:14
