Hi, yes I'm a newbie too, but I was hoping people could help me on this.
I had winME and was capping just fine using a Pinnacle Studio PCTV card up until yesterday (when I installed XP). However, after installation, I've noticed two things that are not so hot. One is that the input image for my caps now has some extra artifacts (a somewhat large black bar) on the left and right side of the screen. I never had this phenomena in my winME days, so I'm guessing it's some compatibility between the card and XP. While this is annoying, I can still correct this with Vdub's cropping feature.
What I cannot correct is the massive loss of frames when capping. Again, when using ME, this never was an issue. I've checked over everything, including getting rid of background tasks, DMA, etc., and somehow I still have a massive loss of frames (20% loss) even at 320x240 resolution. Worse yet, sometimes Vdub just freezes after a while, and I can't do anything except reset.
I may also want to add that the sound is also capped in a terrible fashion... after maybe 7 seconds of jittered sound, there's just no longer any sound captured at all.
Again, I'm using Studio PCTV card, 1 Ghz AMD Athlon, 240 MB ram, 40 Gig 7200 FAT32 drive + 80 gig 7200 ntfs drive.
Can anyone help me with any possible hints or solutions? Thank you very much for your time.
I'm not really an expert but I have the same set up as you as far as the card and OS goes, and capturing is not a problem. Perhaps this is a silly question, but did you download the win XP driver from Pinnacle's website?
BTW, how did you enable DMA? I was told XP didn't use it, and I'm damned if I can find it
Hah, you're a lifesaver, I only checked Pinnacle's website very briskly and did not bother to find any XP drivers.
To enable DMA (though in almost all cases, I'm sure it's enabled already), right click on My Computer -> Hardware -> Device Manager -> IDE ATA/ATAPI controllers -> double click on your primary channel (or secondary in some cases).
It'll bring up another window where you can choose the driver tab and select DMA or PIO
Thanks again... I best download that driver now.
jvc gy-hm 700 drop frame
By seistro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 23rd Sep 2012, 13:31 -
How do I use TEXTSUB.VDF filter in Virtual Dub in WIN 7
By V879 in forum SubtitleReplies: 3Last Post: 10th Jun 2011, 12:16 -
HDV Video >>>>> Use Non drop frame or drop frame and why?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2010, 19:30 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 05:22 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 18:27
