How many types of DVD writers interface out there now beside the below?
SATA serial ATA
PATA parallel ATA
Are new ones come with both that I can switch?
Or, how do find out what I have now (Sony- DW-U18A)
those are the 2 most prevalent ones. might find an occasional scsi or fibrechannel. also usb/firewire for external drives.
look at the cable that attaches to your drive to the motherboard. is it about 2 inches wide or about a half inch. ide is the first and sata the second type.--
Your drive (Sony- DW-U18A) is an EIDE drive. That's Parallel ATA.
https://www.videohelp.com/dvdwriters/sony-dw-u18a/269
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
See the picture here
http://archive.64bits.se/guider/pcbyggarskola/sata.jpg
top is SATA
bottom is IDE -
An add-on identified on the linked page as either "IDE to SATA" or "SATA to IDE" will allow for changing the interface. Also listed are USB to IDE and USB to SATA adapters. I've never used an IDE to SATA or SATA to IDE adapter, but I have used a USB to IDE cable many times whenever I need to temporarily add a another burner. Be sure to check for O/S compatibility.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=%2040000353&Description=sa...2C18%2C21%2C20 -
Adaptors are crappy, will not work mostly.
*** Now that you have read me, do some other things. ***
Can't interface Panasonic DMR-15 DVD Recorder with Sharp LC-42D65U HDTV
By fideauxdon in forum DVD & Blu-ray RecordersReplies: 3Last Post: 2nd Mar 2010, 15:15 -
Replacement for dead Panasonic / Matshita UJ-220S with ATA interface
By Persistence in forum DVD & Blu-ray WritersReplies: 1Last Post: 21st Feb 2010, 09:53 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57 -
hi8 TO DVD VIA i.link interface
By ACKEE in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Oct 2008, 08:11 -
Having a common interface for DVD, web site and BluRay?
By grendizer in forum Authoring (DVD)Replies: 3Last Post: 8th Jul 2008, 19:20
