Will DVD2SVCD run on Windows Vista Premium? Do I need to take any extra steps in the install process?
I used to use this program years ago and was looking to get back in to it.
Thanks,
Kibble
I haven't tried it with Vista, but try installing in 'Run as Administrator' mode. That's best with most installs. If you have problems with that, then R click on the installer, go to 'Properties' and install with 'Run this program in compatibility mode for:XP SP2'. But that's an old program, so compatibility may be a problem.
A list of Vista compatible programs: http://www.iexbeta.com/wiki/index.php/Windows_Vista_Software_Compatibility_List -
If you have a new computer running Vista, it is an easier process with better results to just convert/RIP to DVD instead of creating SVCD's on CD. In most cases, it is also cheaper.
Just my two cents.Google is your Friend -
Originally Posted by johns0Google is your Friend
CPU to MB Compatibility
By jollyjohn in forum ComputerReplies: 2Last Post: 21st Mar 2012, 03:19 -
Vista compatibility help
By wetcamelfood in forum Newbie / General discussionsReplies: 5Last Post: 22nd Dec 2008, 15:00 -
Compatibility issue between Cameo Grabster 200 and Vista
By nawp in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2008, 09:12 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 12:01 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33
