I've just started getting into DVD creation and have some questions.
I've read over the various HOWTO's and some are helpful but most of them use different programs so it gets confusing trying to piece it all together.
What I want to do is take the video from my digital camera and burn it to DVD using freeware.
Ideally I want to capture a tape into scenes and then build a DVD with a menu that allows me to select which scene I want to play back. I don't need any fancy menu creation or video right now but just basic stuff.
So far I have tried Sonic/Roxio MyDVD DE that came with my machine but it does not work very well so I have been searching for other tools.
The steps I see are as follows:
1 - capture video to computer (I have successfully done this using windv.exe)
2 - Convert AVI to mpeg2 format.
What is the best way to do this for free? I've seen the tools such as avi2dvd, mediacoder, and super. Should I use one of these or a different one??? Is there a free tool to capture directly to mpeg2 format instead of having to convert afterwards?
3 - Create a DVD menu.
Some tools I've run across are DVDauthorGUI, DVDflick, DVDstyler, & GuiDVDauthor. Which is the best of these for my needs?
4 - Burn resulting content to DVD. I have used several tools to successfully burn cd's. CdburnerXP, burn4free, etc... so I don't think this will be a problem. Additionally I can burn from some of the authoring tools above.
Am I missing anything? I see some info about demux and remuxing. Is that needed? Please help me get started for items (2) and (3) by suggesting some tools to get the job done without having me to try each and every one of them myself.
PLEASE change the topic subject, use something that better describes your topic. Just click on the edit-button to change it.
edit: Thanks! -
1. OK, good choice.
1A. Editing? You could use VirtualDub and the Cedocida DV Codec. And VD can frameserve the edited video directly to a MPEG encoder.
2. You could try FAVC. It can encode and author your DVD. Or try the HC MPEG encoder.
3. GUI for dvdauthor is a good freeware authoring program. You may want a graphics editor for some added menu design and creation. Gimp is one freeware one. http://www.gimp.org/
4. ImgBurn is highly recommended for burning DVDs.
VD or my tool of choice, VirtualDub Mod, can mux and demux AVI type formats if needed. It can also filter, crop, edit and encode both audio and video to AVI type formats or DV. Well worth having.
And welcome to our forums.
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 13:30 -
Newbie questions on saving, converting, burning, etc..
By osb_tensor in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2010, 23:42 -
Newbie converting DVD to AVI
By nuggett_aus in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 06:31 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 10:23 -
Some (not newbie) questions about video importing/converting/deinterlacing
By F_Krisztian in forum Newbie / General discussionsReplies: 5Last Post: 18th Sep 2008, 07:07
