I'm using ReStream to set the top field first. When I take the file into DVD Lab Pro it tells me that there are open GOPs. How do I set to Close GOPs in Restream? Can this be done?
Thanks,
.....Gord
P.S. If I have this in the wrong forum, my apologies and feel free to move it to the proper area. Thanks again!!!
Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
------------ Groucho Marx -
I don't know if ReStream can do this. One product I know that can do it is the Teco Bitrate Viewer (http://www.tecoltd.com). You'll need the commercial version, which is 29.95. The free version will NOT modify streams! The commercial one can close GOPs. You'll have to demux the video as it can only modify demuxed vided streams.
Perhaps someone knows a better or cheaper way to do this, but the Teco product can do this and it's all I have that can do this. -
I don't think you need to worry about open versus closed GOP. You can typically ignore the message from Dvd Lab (I believe there is even a custom setting that will disable the message). You can read this thread if you want more information:
https://forum.videohelp.com/topic271337.html
- Smells_Like_Feet
Thanks for the information, guys.
I appreciate it.
restream a live stream
By nerojan in forum Capturing and VCRReplies: 2Last Post: 4th Jun 2016, 12:29 -
How to restream mms link?
By Neil_2004 in forum Video Streaming DownloadingReplies: 10Last Post: 2nd Feb 2010, 09:45 -
ReStream
By montgal in forum Newbie / General discussionsReplies: 3Last Post: 5th Nov 2009, 12:18 -
green band after using restream
By thecrock in forum Newbie / General discussionsReplies: 0Last Post: 15th Dec 2008, 14:37 -
Restream question
By Ennio in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2007, 14:33
