I'm transferring some VHS tapes to DVD and have a problem that I assume is caused by incorrect field order. The picture when viewed on the computer is fine but when viewed on TV any motion is blurred/jerky.![]()
My method is as follows:
1. I record the video using Main Concept PVR v1.1
2. I demux the MPEG file to mpv & mpa using DVD-Lab Pro 2
3. I edit the video from those mpv & mpa files using Cuttermaran
4 I take the cut mpv & mpa files back into DVD-Lab Pro and create the DVD
My question is: where in this list can I change the field order? Or is there some other step/software I need to use? I haven't done any of this for quite a long time and must be forgetting something. Any help would be much appreciated!
Thanks,
.....Gord
Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
------------ Groucho Marx -
If using DV then yes field order is BFF but if it is not DV then use top field first (TFF).
Donadagohvi (Cherokee for "Until we meet again") -
Thanks very much guys.
I'll give this a try.Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 13:41 -
field order fix in DGindex - problem?
By spiritgumm in forum Video ConversionReplies: 0Last Post: 29th Jun 2010, 06:47 -
What's the right way to fix a field order problem?
By brassplyer in forum EditingReplies: 13Last Post: 28th Dec 2009, 10:03 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 06:06 -
1. Field order problem? & 2. How to fix?
By fvisagie in forum Authoring (DVD)Replies: 29Last Post: 3rd Dec 2008, 20:31
