Hi
I need a filter which can record frame number whenever a key is pressed.
Do we something like this is VDub or AVISYNTH ? If not, then how can I make a vdub filter/ avisynth script ?
thnaks
If you just want a list of frame numbers, in AvsP you can set bookmarks with a keypress (^B), and use a macro to save the resulting list of frames to a text file:
Code:filename = avsp.GetSaveFilename(title='Save bookmarks to text file') f = open(filename, 'w') for bm in avsp.GetBookmarkList(): f.write(str(bm)+'\n') f.close() -
thanks for the quick reply !
can you suggest a modification .... something that records the frame number as well as the key that has been pressed -
That's beyond my ability. And I guess that since many keystrokes are already defined in AvsP as commands, that you couldn't do it in the general case, at least easily. Maybe you should look into keyloggers.Originally Posted by blaze01
Anyway, if you want to ask the author, post in the AvsP thread at Doom9.
Removing Logos using DeLogo vdub filter
By Matt D in forum EditingReplies: 67Last Post: 6th Apr 2016, 10:26 -
Which is the best VDub filter to fix this video/image?
By zanos in forum RestorationReplies: 7Last Post: 12th Feb 2009, 16:37 -
Applying a filter without recompressing in VDub
By chrisr34000 in forum EditingReplies: 5Last Post: 25th Jan 2008, 17:42 -
ACDsee Filter&VDUB
By mv0930 in forum Newbie / General discussionsReplies: 0Last Post: 4th Sep 2007, 12:27 -
Vdub Filter Chain
By christopheramos in forum Video ConversionReplies: 16Last Post: 3rd Sep 2007, 07:57
