Got a question about capturing HDV footage via firewire, SDI or component cables.
Which method will I be able to gain picture quality?
Results 1 to 11 of 11
Which camcorder? You need to get up to the Canon XH-G1 with Jackpack option for SDI.Originally Posted by danielheldman
For the rest, IEEE-1394 (firewire for HDV format), HDMI for YCbCr.
The HDMI out may be better than HDV for live camera, not for HDV tape playback. Analog component will be less quality than HDMI but for live camera may be superior to compressed HDV. You need to test.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I want to find out the following few different settings.
JVC GY-HD110u to capture live to my Mac Pro using BlackMagic Design Multibridge via component cables. I captured 10 bit uncompressed 4:2:2 and I think this will give me the best quality.
VS.
Capture the footage to mini HDV tape and capture it thru firewire to my Macpro and capture footage to 4:2:2 uncompressed HD.
VS.
Capture the footage to mini DV tape and using component cables via multi bridge tio my Mac Pro and capture footage to 4:2:2 uncompressed HD.
I also have a Sony A1U and would like to test different capture method as well. -
Success at beating HDV over firewire depends on where the GY-HD110u taps the YPbPr output in the camera, that is before or after HDV compression. You should ask JVC support or in the JVC forums.Originally Posted by danielheldman
I suppose you have a 10bit uncompressed project and you want to import the HD110u file. That camera does not produce 10bit resolution gray scale. You would need to go higher.Recommends: Kiva.org - Loans that change lives.
edDV...wah!!! very impressed with your knowledge. Yes, I have a 10 bit uncompressed project on hand and the budget is really tight.
Any suggestion on the cameras or any go around? -
very interesting discussion. If take the HDV camcorder that has component out puts, connect it to a capture card that takes component in and hooked up to a mac using final cut pro to capture 10 bit compressed 4:4:4, will I get the 4:4:4 quality?
Unlikely. It again depends on the internal processing for the camera section of the camcorder. A typical camcorder samples RGB off the sensor, then processes to a YCbCr 4:2:2 or 4:2:0 output to the HDV compressor. The output of the HDV compressor is always 4:2:0 (quarter bandwidth chroma).Originally Posted by brucejackson
The HDMI and analog component outputs might tap from the pre-compression 4:2:2 point in the flow or at the 25Mb/s 4:2:0 output from the HDV compressor.Recommends: Kiva.org - Loans that change lives.
A true 10bit to SDI HD camera would be at the HDCAM level. A bit pricy but not to rent for a short shoot.Originally Posted by danielheldman
http://www.broadcaststore.com/store/prod_search_results.cfm?category_search=1011
Nothing wrong with what you are doing.Recommends: Kiva.org - Loans that change lives.
Even if you think you're getting 4:4:4, the sensor itself may not deliver that chroma resolution. 3 sensor cameras can.
Capture SDI video as H264 or other codecs?
By maxslomoff in forum Capturing and VCRReplies: 3Last Post: 19th Feb 2012, 14:13 -
a good BOB? for DVCPRO via SDI output TO CAPTURE into Precision 690 PC?
By cowtowne in forum Capturing and VCRReplies: 0Last Post: 14th Feb 2011, 12:01 -
Thanks HDV to tape DV via FireWire with JVC GY-HD100
By RodK in forum Capturing and VCRReplies: 4Last Post: 26th Jun 2009, 12:06 -
Sony HDV HC5 Camcorder and Firewire Cable
By fjmr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Jul 2008, 06:38 -
Frame drop in firewire HDV transfer
By Dinu Bandyopadhyay in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 19th Oct 2007, 12:29
