hi
i have a problem with the newer virtualdub and virtualdub mod.
when i select compresion the program crashes and i get an error message about conflict with four cc code divx
it seems there is an conflict between divx 6 and vitualdub (only newer version my older one still works)
same goes for virtualdubmod .
i tried uninstalling and installing the divx 6 again then for a brief moment the problem seem to be solved
but once i used the divx codec to encode something it encoded the file,but afterwards the problem is back
is there a way to fix this problem,i got a reg divx 6 and i would like to be able to use it.
Results 1 to 10 of 10
Can you post the full error message?
Has you encoding worked successfully ever prior to this?
Try using XVID or AVC compression for a moment (on a few frames or sample clip) to see if that induces a crash (just trying to isolate the problem) -
hi
here's the crash report
VirtualDub crash report -- build 27021 (release)
Disassembly:
77e56b00: 085653 or [esi+53h], dl
77e56b03: e89f490000 call 77e5b4a7
77e56b08: 8bf8 mov edi, eax
77e56b0a: 897ddc mov [ebp-24h], edi
77e56b0d: 64a118000000 mov eax, fs:[00000018]
77e56b13: 8945d8 mov [ebp-28h], eax
77e56b16: 53 push ebx
77e56b17: 8b4030 mov eax, [eax+30h]
77e56b1a: 56 push esi
77e56b1b: ff7018 push dword ptr [eax+18h]
77e56b1e: ff151010e477 call dword ptr [77e41010]
77e56b24: 834dfcff or dword ptr [ebp-04h], 0ffh
77e56b28: 3bfe cmp edi, esi
77e56b2a: 0f8dd94a0000 jge 77e5b609
77e56b30: 57 push edi
77e56b31: e830390000 call 77e5a466
77e56b36: 33c0 xor eax, eax
77e56b38: e9cf4a0000 jmp 77e5b60c
77e56b3d: 64a118000000 mov eax, fs:[00000018]
77e56b43: 8985a0fbffff mov [ebp-460], eax
77e56b49: 8b80f40b0000 mov eax, [eax+bf4]
77e56b4f: 8945e4 mov [ebp-1ch], eax
77e56b52: e93b4a0000 jmp 77e5b592
77e56b57: ff75e4 push dword ptr [ebp-1ch]
77e56b5a: e807390000 call 77e5a466
77e56b5f: e9644a0000 jmp 77e5b5c8
77e56b64: f6450c04 test [ebp+0ch], 04h
77e56b68: 6a00 push 00h
77e56b6a: 58 pop eax
77e56b6b: 0f95c0 setnz al
77e56b6e: 40 inc eax
77e56b6f: e9014b0000 jmp 77e5b675
77e56b74: 837d1002 cmp dword ptr [ebp+10h], 02h
77e56b78: 0f8438390000 jz 77e5a4b6
77e56b7e: e9f33e0200 jmp 77e7aa76
77e56b83: 85d2 test edx, edx
77e56b85: 0f856e390000 jnz 77e5a4f9
77e56b8b: 33c9 xor ecx, ecx
77e56b8d: e970390000 jmp 77e5a502
77e56b92: 8bc1 mov eax, ecx
77e56b94: 8d5001 lea edx, [eax+01h]
77e56b97: 8a08 mov cl, [eax] <-- FAULT
77e56b99: 40 inc eax
77e56b9a: 84c9 test cl, cl
77e56b9c: 75f9 jnz 77e56b97
77e56b9e: 2bc2 sub eax, edx
77e56ba0: 40 inc eax
77e56ba1: e9d53c0000 jmp 77e5a87b
77e56ba6: 55 push ebp
77e56ba7: 8d6c24a4 lea ebp, [esp-5ch]
77e56bab: 81ec98000000 sub esp, 00000098
77e56bb1: 8b556c mov edx, [ebp+6ch]
77e56bb4: 8b4d68 mov ecx, [ebp+68h]
77e56bb7: 8b4578 mov eax, [ebp+78h]
77e56bba: 53 push ebx
77e56bbb: 8b5d74 mov ebx, [ebp+74h]
77e56bbe: 56 push esi
77e56bbf: 8b7570 mov esi, [ebp+70h]
77e56bc2: 57 push edi
77e56bc3: 33ff xor edi, edi
77e56bc5: f7c1f8effcaf test ecx, affceff8
77e56bcb: 897550 mov [ebp+50h], esi
77e56bce: 894544 mov [ebp+44h], eax
77e56bd1: 897de4 mov [ebp-1ch], edi
77e56bd4: 8955c8 mov [ebp-38h], edx
77e56bd7: 89554c mov [ebp+4ch], edx
77e56bda: 895d54 mov [ebp+54h], ebx
77e56bdd: 0f8526cc0200 jnz 77e83809
77e56be3: f7c100000010 test ecx, 10000000
77e56be9: 6afe push 0feh
77e56beb: 58 pop eax
77e56bec: 0f854571ffff jnz 77e4dd37
77e56bf2: 8b4564 mov eax, [ebp+64h]
77e56bf5: 8b4024 mov eax, [eax+24h]
77e56bf8: 3bc7 cmp eax, edi
77e56bfa: 8945c4 mov [ebp-3ch], eax
77e56bfd: 7540 jnz 77e56c3f
77e56bff: 3b db 3bh
Built on KOS-MOS on Tue Feb 06 21:24:09 2007 using compiler version 1400
Windows 5.1 (Windows XP build 2600) [Service Pack 1]
EAX = 7989d963
EBX = 00142f68
ECX = 7989d963
EDX = 7989d964
EBP = 0012eb84
ESI = 00000000
EDI = 000004e4
ESP = 0012eb68
EIP = 77e56b97
EFLAGS = 00010246
FPUCW = ffff027f
FPUTW = ffffffff
Crash reason: Access Violation
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'kernel32'...
...reading address 7989D963...
...while opening video codec with FOURCC "divx" (compchoose.cpp:167)...
...while enumerating video codecs (compchoose.cpp:155).
Pointer dumps:
EBX 00142f68: 000004e4 00000000 7ffb0002 7ffb001c 00000000 7ffb021e 00000000 7ffb0222
ESP 0012eb68: 0012ebbc 00000001 0112bd58 77f988f0 77f421e0 00000058 00000000 0012ec44
0012eb88: 5ff01ed1 00000003 00000000 7989d963 ffffffff 0012ebbc 00000001 01cd52c0
0012eba8: 5ff09f36 0012ebbc 7989d963 00000001 00000003 5ff00000 0065006b 006e0072
0012ebc8: 006c0065 00320033 0064002e 006c006c 5ff00000 5ff27c0c 5ff27c0c 0012f2bc
EBP 0012eb80: 00000000 0012ec44 5ff01ed1 00000003 00000000 7989d963 ffffffff 0012ebbc
0012eba0: 00000001 01cd52c0 5ff09f36 0012ebbc 7989d963 00000001 00000003 5ff00000
0012ebc0: 0065006b 006e0072 006c0065 00320033 0064002e 006c006c 5ff00000 5ff27c0c
0012ebe0: 5ff27c0c 0012f2bc 0045004b 004e0052 004c0045 00320033 0044002e 004c004c
Thread call stack:
77e56b97: kernel32!FindNextFileW [77e40000+1693e+259]
5ff01ed1: umxw!00001ed1
5ff09f36: umxw!??4MUmxApi@@QAEAAV0@ABV0@@Z [5ff00000+4371+5bc5]
5ff10e26: umxw!??4MUmxApi@@QAEAAV0@ABV0@@Z [5ff00000+4371+cab5]
5ff0a0e5: umxw!??4MUmxApi@@QAEAAV0@ABV0@@Z [5ff00000+4371+5d74]
5ff0a2e6: umxw!??4MUmxApi@@QAEAAV0@ABV0@@Z [5ff00000+4371+5f75]
5ff022c3: umxw!000022c3
77f55cc0: ntdll!LdrShutdownThread [77f40000+12904+33bc]
77f4c284: ntdll!NtSetInformationProcess [77f40000+c278+c]
77e53b45: kernel32!LoadLibraryW [77e40000+13b38+d]
76af3416: WINMM!OpenDriver [76af0000+30e3+333]
76af3289: WINMM!OpenDriver [76af0000+30e3+1a6]
76af311f: WINMM!OpenDriver [76af0000+30e3+3c]
77d1c2de: USER32!CharLowerBuffA [77d10000+c271+6d]
77da1c0d: ADVAPI32!RegQueryValueExW [77da0000+1b8b+82]
77f4b5d4: ntdll!NtClose [77f40000+b5c8+c]
77da17b9: ADVAPI32!000017b9
77da1859: ADVAPI32!RegCloseKey [77da0000+17d8+81]
73b44c74: MSVFW32!ICDecompress [73b40000+478b+4e9]
77f48bcd: ntdll!RtlFreeHeap [77f40000+8a3e+18f]
77d1ae50: USER32!wsprintfW [77d10000+ae3e+12]
76af30f6: WINMM!OpenDriver [76af0000+30e3+13]
73b447d7: MSVFW32!ICDecompress [73b40000+478b+4c]
73b43854: MSVFW32!ICOpen [73b40000+378e+c6]
77c0be9a: msvcrt!_flsbuf [77be0000+2bc2b+26f]
77f503c6: ntdll!LdrUnlockLoaderLock [77f40000+1034e+78]
77f50403: ntdll!LdrUnlockLoaderLock [77f40000+1034e+b5]
77f67ba8: ntdll!LdrUnloadAlternateResourceModule [77f40000+27a54+154]
77f49037: ntdll!RtlFreeHeap [77f40000+8a3e+5f9]
77f58988: ntdll!LdrShutdownThread [77f40000+12904+6084]
77f5904d: ntdll!RtlComputePrivatizedDllName_U [77f40000+189d2+67b]
77f50f67: ntdll!LdrUnloadDll [77f40000+10a4a+51d]
77f50ab7: ntdll!LdrUnloadDll [77f40000+10a4a+6d]
73b4466d: MSVFW32!VideoForWindowsVersion [73b40000+4353+31a]
73b43725: MSVFW32!ICInfo [73b40000+34d2+253]
77f4980f: ntdll!RtlUnlockHeap [77f40000+97ea+25]
77f4982f: ntdll!RtlUnlockHeap [77f40000+97ea+45]
0057dcb9: _vswprintf_helper()
77e5399e: kernel32!GlobalUnlock [77e40000+1391c+82]
76af39f6: WINMM!CloseDriver [76af0000+38da+11c]
0057dd39: _vswprintf_c_l()
004906a9: isEqualFOURCC()
00462000: ChooseCompressor()
77d1605c: USER32!GetSystemMetrics [77d10000+6003+59]
77d1604e: USER32!GetSystemMetrics [77d10000+6003+4b]
5b195643: uxtheme!CloseThemeData [5b190000+42d7+136c]
77d158ce: USER32!DefWindowProcW [77d10000+582e+a0]
5b191b11: uxtheme!DrawThemeParentBackground [5b190000+1677+49a]
77d15a63: USER32!GetWindowThreadProcessId [77d10000+59cd+96]
77d14124: USER32!GetWindowLongW [77d10000+4092+92]
77d158a7: USER32!DefWindowProcW [77d10000+582e+79]
77d15899: USER32!DefWindowProcW [77d10000+582e+6b]
004b7bca: VDUIFrame:
efProc()
004a9480: _catch$?MainWndProc@VDProjectUI@@IAEJIIJ@Z$0()
004a8f5b: VDProjectUI::WndProc()
004b8145: VDUIFrame::StaticWndProc()
004a7016: VDProjectUI::SetVideoCompressionAsk()
004a795f: VDProjectUI::MenuHit()
5b191b48: uxtheme!DrawThemeParentBackground [5b190000+1677+4d1]
efProc()
004a912b: _catch$?MainWndProc@VDProjectUI@@IAEJIIJ@Z$0()
77f5679b: ntdll!LdrShutdownThread [77f40000+12904+3e97]
77d1400a: USER32!GetWindowLongA [77d10000+3fd6+34]
77d14001: USER32!GetWindowLongA [77d10000+3fd6+2b]
746ac331: MSCTF!TF_UninitSystem [746a0000+ba35+8fc]
746ac336: MSCTF!TF_UninitSystem [746a0000+ba35+901]
746abf2c: MSCTF!TF_UninitSystem [746a0000+ba35+4f7]
77d24f6c: USER32!GetAsyncKeyState [77d10000+14e1e+14e]
77d13a50: USER32!00003a50
77d13b1f: USER32!00003b1f
77d13d79: USER32!GetMessageW [77d10000+3c54+125]
77d14374: USER32!DispatchMessageA [77d10000+4369+b]
0048e583: WinMain@16()
00584218: __set_flsgetvalue()
005843c4: _getptd_noexit()
00581895: __tmainCRTStartup()
70a9f1ab: SHLWAPI!PathFindOnPathA [70a70000+29f50+525b]
77e614c7: kernel32!GetCurrentDirectoryW [77e40000+21483+44]
-- End of report
and i can not try any other compresion because
when i go the menu bar video and in the drop down menu select compresion the program crashes
so i can't select even an other codec to use -
I use the latest pro divx codec and the latest vdub/vdubmod with no issues now, however......
You don't by any chance have the Panasonic DV codec installed? I found it messed up in vdub by being selected as the default divx codec by Vdub. I never figured out why that was, so I uninstalled the Pan DV.
btw) I reinstalled the DV codec and it caused the same issue so I just removed it until I need it again. I don't know if the issue is with Panasonic using a reserved fourcc or descriptor or Vdub misinterpreting the fourcc thinking the DV codec is the default mpeg4 (divx) codec. -
Yes, Panasonic DV codec sometimes says it can handle Divx (and other codecs like HuffYUV) and causes a crash. If you need a VFW DV codec use Cedocida. It's much better.
VirtualDub crash report -- build 27021 (release)27021 is not so new anymore. try the latest Virtualdub which is 1.8.0 (experimental) or the latest stable one 1.7.8only newer version my older one still works
That was my first thought also but it gives an error message about the panasonic dv codec which the OP does not mention.You don't by any chance have the Panasonic DV codec installed?
Seems like I had problems with the Divx 6.8 codec trying to open divx 3.11 files and had to reinstall the 3.11 codec. I had to uncheck "use advanced hardware overlay" in the 6.8 codec configuration utility also.
Post the crash report at...
http://forums.virtualdub.org/
and Avery will be able to tell you exactly what caused the crash and hopefully what to do to correct it. -
hi
i have no panasonic dv codec installed
i tried the new version of virtualdub but got the same error message
i now also have posted me error report on virtualdub forum -
hi
could something like directshow cause such an error
i upgraded my g-spot from 21 to 22
and now i get a simelar error message
the message says that while trying to access directshow,directshow crashed
and the crash is also caused by divx
that's why my question -
The error could be anywhere in Directshow, VFW, the Divx codec, some other installed filter, and VirtualDub.
VirtualDub does it's own AVI file parsing but uses VFW codecs for video decoding.
Most media players use DirectShow so you would be using DirectShow and DirectShow video decoders.
I would just use Xvid instead of Divx.
Interesting Build of VirtualDub/Mod
By Soopafresh in forum Video ConversionReplies: 8Last Post: 12th Oct 2012, 01:49 -
Divx/Xvid problem in Virtualdub (not mod)
By leeqk in forum Newbie / General discussionsReplies: 14Last Post: 11th Apr 2010, 02:18 -
Virtualdub Mod and Vobsub woes
By TheLaserdisc in forum Video ConversionReplies: 4Last Post: 30th Dec 2008, 01:03 -
problem with Dr Divx & VirtualDub Mod
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2008, 14:59 -
Encoding audio with VirtualDub MOD
By GangstaRap in forum AudioReplies: 5Last Post: 19th May 2007, 08:20
