Hi, Im new to this forum and have done video editing in the past, but don't understand much about the technical end of it. I have had a relative build my previous systems, but is not available and I need an upgrade. I had pinnacle dv500 in my last system, but gave up on it when sp2 interfered with it. I am now in the process of having my local computer store build me a new system, but I would like to get some ideas on a good video capture card and editing software. I would like to keep the cost of the whole system under or around 2000.00, obviously less if possible.
I video stock car and kart races, I use a Canon GL2. I would appreciate any info, and recommendations on what you have found works best, within my budget. Thanks in advance. Tonya
What other needs do you have? You can cap the GL2 via IEEE-1394 and WinDV. You can cap analog through the GL2.
Do you need a tuner?
What editing software are you using?
Do you need hardware transition/effects acceleration?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I don't need a tuner. With the old system I was captureing via Pinnacle dv500 and using adobe premier for editing.
I really only did basic editing. Added music, cut out some unwanted footage, added transitions, slow mo and titles, I would like to experiment a little more though. I had 2 monitors set up and I need to continue with that. I make mupltiple copies to sell at the racetracks(sorry I neglected to mention that).
Right now my old system is not functioning at all, I am not sure where the problem is, I can't even access it in safe mode. I really won't know until I get it to the computer shop what I can use and what I can't. The one I have now is probably about 3-4 years old so I don't think its a good move to invest too much into this system.
Thanks for your help
Tonya -
IEEE-1394 + Premiere Pro gets you started since you already know Premiere. Everything will seem fast relative to the Pentium 1-3 days.
Need suggestions for inexpensive surround sound system
By boowho in forum AudioReplies: 5Last Post: 17th Aug 2010, 21:04 -
Specific system needed for AVCHD1080 -> DVD - suggestions please!
By Telek in forum Newbie / General discussionsReplies: 19Last Post: 10th Mar 2010, 15:17 -
Operating System Suggestions
By radiotaught in forum Newbie / General discussionsReplies: 30Last Post: 3rd Jun 2009, 09:40 -
I want some suggestions for setting up a speaker system
By wan2no in forum AudioReplies: 4Last Post: 12th Aug 2007, 00:09 -
Hookup a video game system so that you may record video on a PC?
By KameronK in forum Newbie / General discussionsReplies: 7Last Post: 25th Jul 2007, 02:11
