When I downloaded Boris FX continuum complete to C drive where premiere pro is installed, but it makes premiere pro performance slow.
Can I download to D drive instead of C drive for faster performance??
It would make a difference only if you are out of disk space on C. Better to move Premiere Pro's scratch disk (cache) off the OS drive. Check to see if Boris FX uses a separate cache an move that off the C: drive as well.
Premiere Pro scratch disk settings are under "preferences".Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thank you for quick replay. So you mean that I have to setup caches place to D drive from C drive??
I found out that I already setup caches in D drive. But it is still slow
So I checked caches file. It is about 55mb. Shuld I clean everything in cache file for faster performance? -
Adobe Premiere Pro How do I make the video Bigger?
By Devilsadvocate in forum EditingReplies: 5Last Post: 25th Mar 2012, 15:44 -
FREE transition plugins for Premiere pro cs3
By mudh in forum EditingReplies: 0Last Post: 14th Oct 2011, 17:00 -
Plugins for premiere
By IT learner in forum EditingReplies: 2Last Post: 11th Sep 2011, 15:29 -
Boris Fx and Sony Vegas Pro 8
By mashimiriam in forum EditingReplies: 5Last Post: 27th May 2008, 22:27 -
Newbluefx PLUGINS for Adobe Premiere are here!!!!!!!
By zojpie in forum Latest Video NewsReplies: 0Last Post: 28th Jan 2008, 12:04
