Is it possible to reduce the fps in staxrip. I am converting captures to mkv. I can convert it but it runs my processor to high to play it back. I am assuming it is because the frames are at 59fps (Hd capture) When I look at HD downloads that I have they mostly have 23.976 fps. I can get the bitrate and resolution the same as my downloads but I can't find anywhere to reduce the frames.
Give more information about your source files. 59.976fps 1080i interlaced source?
I have captured them from a DVB-S capture card. They are 1280x720 Mpeg2 files.
I have not been able to change the fps within StaxRip either, and using the x264 command --fps (enter framerate) doesn't work either. I'm sure someone may have a better solution but here's one that works for now.
Change the fps beforehand.
Be careful when using VirtualDub since it doesn't add or subtract frames when reducing, so it would throw your audio out of sync.
TMPGEnc Xpress will do it fine.
Use a lossless codec like HuffYUV to preserve quality and input that into StaxRip.I hate VHS. I always did.
Staxrip. No sound?
By The.King in forum Video ConversionReplies: 2Last Post: 23rd Apr 2012, 14:25 -
StaxRip mastered...
By The.King in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 15:02 -
Staxrip problems?
By zelky in forum Video ConversionReplies: 3Last Post: 5th Jun 2010, 07:40 -
presets for Staxrip
By greendesert in forum Video ConversionReplies: 0Last Post: 7th Jul 2009, 11:06 -
Reducing Ref-Frames in x264 videos
By hulked in forum Video ConversionReplies: 0Last Post: 7th Jan 2009, 11:10
