OK, this is soooo frustrating! I have no sound when I play media files - mps, mpeg videos, avi files. nothing. I I do have sound when I watch TV on my computer so i know the speakers work, etc. I checked the volume control in windows and all are "on" (no mute).
Any ideas? Seems this has happened before on another computer of mine but I can't recall the solution.
	Try VLC. Want my help? Ask here! (not via PM!)
	tried those things, thanks though. I have several players, no success. I uninstalled audio car then re-installed it, no help. Must be some software problem somewhere. I use a wireless transmitter for sending music to my home stereo receiver - maybe that is mixed up in this somehow. I'm not sure how to check it though.
 Crap.
	Can you get audio files to play? like .mp3?
 Do you hear beeps, browser clicks etc? (the reason I ask is some TV tuner cards have separate audio not rendered through the sound card, just trying to isolate the problem)
	OK, I solved the problem!!! First, i searched google for any possible registry issues which i recall having before. Then, I saw a codec checking program (part of klite or something)....ran that, didn't help. THEN I swore a bit, complained to my family and, as a last resort........
 checked the plug int the back of the computer that had come lose.......
 Very embarrasing. In my defense, I HAD plugged a different speaker set in earlier but it didn't work because the lose plug was from the audio out to the TV tuner card.
 Thanks for trying to help.
  audio broken in all media filesBy amarkudre in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2010, 04:14
  No sound when converting video files using Daniusoft Media Converter ProBy cookm75 in forum Video ConversionReplies: 6Last Post: 29th Apr 2010, 07:42
  Compare Audio Files - Extract Common SoundBy ContactGT in forum AudioReplies: 8Last Post: 28th Aug 2009, 14:36
  No Sound When playing MKV files in wmp or media player classicBy tmiller_15 in forum Blu-ray RippingReplies: 2Last Post: 13th Jun 2009, 00:24
  converting windows media audio/video playlist filesBy pw29010 in forum Video ConversionReplies: 2Last Post: 23rd Nov 2008, 13:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
