so after a lot of thought i think the slingbox is the best way for me to record 360 gameplay. it allows me to play on the tv in HD and then streams an SD signal to the network.
will it clog up the network because i want XBL to run smootly
what i was wondering is how the hell do you record using it?
also what format is the recorded video because i want to be able to edit it and i dont know what programs i can use?
finally how big is about 4 hours of video from it?
thanks for the help
Results 1 to 1 of 1
Capture Video from a Slingbox
By DLGleason in forum Capturing and VCRReplies: 2Last Post: 10th Oct 2011, 10:30 -
slingbox owners? are you happy?
By buzzinhornets in forum Media Center PC / MediaCentersReplies: 4Last Post: 18th Mar 2011, 07:33 -
Slingbox
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2008, 18:54 -
HAVA vs. Slingbox
By RoganSarine in forum Capturing and VCRReplies: 0Last Post: 2nd Jan 2008, 19:29 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 09:06
