I made a few copies of some movies that i own. When attempting to play them in the dvp5982, the root menu comes up with Video ts, audio ts, and the name of the movie folder. When i press disk menu, is says invalid. If I want to watch the movie, i have to pick the ts files and play it that way. It will play the ts files fine. Has anyone else encountered this? I have a dvp642 and it plays them fine. I havent changed the format or anything else
Assuming the 5982 doesn't have any issues with other movies and commercial discs, I would be suspicious of your copying/burning process and/or the media.
You could unplug the unit for 30+ minutes and see if it will reset. It may also be worth checking for a firmware update.
Aside from that, I haven't heard of this particular issue before.Google is your Friend -
Sounds as if you somehow burned the disc as a data disc rather than a DVD format disc. What was your process
DVD shrink then nero 6 ultra set to dvd video
I was thinking it could have been how it was burned but i put the same disc into my dvp642 and the disc menu came right up -
Figured it out...its only the ativa discs that it wont play...every other disc is fine
well now the maxell discs wont play either...theyre comin up as data aswell. They are still playing fine in my 642
Try burning the disk using the latest version of Imgburn (use the build option and select the files from the shrinked folder) and see if that fixes the problem, if so then its your Nero, which is also wierd. My 642 (RIP little buddy) played everything, but would not play a dvd burned as a data disk (Yeah, I've done that as well) so perhaps your 5982 is having a brain freeze. I like Imgburn so much I only use Nero to backup CD's now.
well i just used it and theyre playing perfectly......goodbye nero
LG RHT497H DVD recorder - XP not reading DVDs made
By jollysuper in forum Latest Video NewsReplies: 2Last Post: 28th Mar 2012, 11:01 -
Problem with recently burnt DVDs not reading suddenly in any player
By Xmetalfanx in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Jul 2011, 22:27 -
DVD drive stopped reading DVDs for a very random reason..
By narutoball in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Oct 2008, 15:23 -
Best burner for reading DVDs
By samijubal in forum DVD & Blu-ray WritersReplies: 15Last Post: 23rd May 2008, 11:21 -
Are some DVD burners better than others at reading/ripping scratched DVDs?
By davlor in forum DVD RippingReplies: 11Last Post: 2nd Dec 2007, 15:03
