Ok, so I installed this game (along with the expansions) without any problems. However, the problem comes when I start it up. It'll load everything up normally, and then freeze up. I can exit via ctrl+alt+delete, but I checked the task manager one time during the freeze up, and noticed that my CPU usage spikes up to between 90-100%, and the memory usage reaches over 100,000 k. Obviously, something is seriously wrong given my specs (see below):
Microsoft Windows XP Pro
Intel T2500 (2.0 GHz)
2 GB RAM
ATI Mobility Radeon X1600 (using Omega 3.8.421 drivers)
100 GB Hard Drive
Any ideas? I've tried playing it with the CD (didn't work), and I tried ripping it to my laptop as an ISO and using Daemon Tools (also didn't work).
Uninstall the game. Ensure you have all of the latest drivers installed (video, audio, etc.). Then install the game again and test (before installing all of the expansion packs).
You may also want to test/reinstall DirectX.Google is your Friend
Problems running software to capture PS3 game play?
By Agent 0008 in forum Capturing and VCRReplies: 9Last Post: 31st Mar 2011, 16:50 -
Problem running vob2mpg
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2010, 10:29 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59 -
running spybot but laptop turns off
By Tbag in forum ComputerReplies: 18Last Post: 25th Nov 2007, 20:34 -
DVD FLICK running problem
By gap0306 in forum Video ConversionReplies: 2Last Post: 14th May 2007, 23:54
