Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. How i could do it in good way , I just needed to save some good youtube movies to watch it later on the PC .. I think its Orbit who will do it ..
    But Orbit even last version i downloaded today dose nothing all its gives me is an error and no movie has been saved.
    Just any one has experience with this please let me know...........
    Thanks everyone.
    Thanks,
    No Pain, No Gain.
  2. Did you read the sticky right above you?
    Feb 2008
    Twin Peaks
    There is a shareware program called videoget it works really good.
    Jan 2007
    a ff tool called unplug
    and sothink flv/swf video capture
    and the website keepvid.com
  5. Actually you don't need to install any software if you don't want to
    Youtube videos are saved to your temporary internet files directory if you let them load completely.
    1) Just clear out the existing stuff to allow easy identification of the new youtube file (internet options => delete temporary internet files)
    2) Go to the youtube page, let it load
    3) Check the temp internet files directory. Copy the new .flv file to your desktop (or wherever) and rename it to whatever you want.
    The benefits of some of the programs listed above include queing, automation of the process, and some even encode to avi for you
    Cheers
