I have Pentium 4, 2x200 gig hard drives.
What is the largest external hard drive I can add, and what is the best method. USB or Firewire.
Whatever size you can find and has a good cost/benefit ratio, but I've always been partial to firewire external drives. They're a bit harder to find and slightly more expensive, but they are more dependable for long, sustained transfers, plus you can daisychain them.
Is there a limit? You are good for TB or more for a single drive.
Best connections?
1. eSATA (as fast as internal drive but may require a card)
2. Firewire 800 (expensive and also requires a card)
3. Firewire 400 (you seem to have it)
4. USB2 (cheaper but adds load to CPU)Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
External Hard Drive Recommendations.
By bbanderic in forum ComputerReplies: 4Last Post: 1st Jan 2010, 08:42 -
external hard drive
By alintatoc in forum ComputerReplies: 20Last Post: 26th Sep 2009, 19:54 -
Adding external hard drive
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 14th May 2008, 02:07 -
External Hard Drive > TV?
By jason in forum Newbie / General discussionsReplies: 36Last Post: 12th Mar 2008, 09:32 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 08:47
