Hi, I want to remove the extras from a dvd but keep all the original menus. Can you tell me what's the simplest way to do this, without adding a still image instead of the extras.
	Vobblanker, but probably not the easiest but click on it for guides.
	Vobblanker is free, but not that easy to understand. Try DVD Rebuilder, it is not free, but you just highlight what you do not want, that simple.
 Other is DVD Remake, this one let you change DVD navigation, but it takes time to understand DVD commands.
	I've managed to remove the extras using VobBlanker but I can't open then new dvd with WinDVD. It works fine with PowerDVD. And after I edit it with Dvd Shrink it works but I can't open the subtitle menu (with WinDVD). Any ideas why?
  Add subs to existing authored DVD/Keep original Menus?By louv68 in forum Authoring (DVD)Replies: 4Last Post: 19th Feb 2012, 19:56
  Convert Closed Captions to Subtiltle on DVD-Keep Original MenusBy emsdallas in forum SubtitleReplies: 1Last Post: 2nd Oct 2010, 18:42
  burn multiple dvds with original menusBy pins123 in forum DVD RippingReplies: 1Last Post: 26th May 2010, 17:31
  Wall-E... remove extrasBy gbabione in forum DVD RippingReplies: 7Last Post: 24th May 2010, 03:35
  keeping the menus, removing the extrasBy Belfour in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2007, 10:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
