i have a windows XP pro machine that the 2 com serial ports went out. device manager said they were working ok but i couldnt get to work with anything. so i bought a 2 com serial PCi card and installed it. the machine named them Com4 and com5. i went into device manager and uninstalled the old com ports(1&2) then renamed them to com10 and com11. i renamed the new com ports 1 and 2. device manager shows the new com ports as 1 and 2. but when i use the ports the software says it cant initialize them. any ideas?
	Might be useful to know what hardware/software you are using with the comm ports.
 Some call specifically to the port address and do not care about the labeling.
  turn an audio in port into an audio out port?By cduval04 in forum AudioReplies: 12Last Post: 19th Dec 2009, 09:03
  How to connect VGA port on laptop to Svideo port on tvBy hulk420 in forum ComputerReplies: 4Last Post: 5th Jun 2008, 16:07
  need serial numberBy besty01 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 24th Jan 2008, 08:29
  serial portsBy rubberman in forum ComputerReplies: 10Last Post: 17th Jan 2008, 11:40
  question about why some avi's will not play from DVD USB portBy jimdagys in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Nov 2007, 06:33
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
