Hello, all,
I've done some searching and I can't seem to find any information on this error (not even from LG's own support, which is another story...). When viewing DVD's (I haven't tried it with other disc formats yet) my LG LDA-531 player, which was working perfectly up until two weeks ago, will sometimes halt in the middle of playback and show an on screen error message that says "No Memory Card Present." In order to get it going again, I have to open and close the disc tray. I can't seem to find any information on this error, so I'm hoping one of you good citizens will be able to help out as to a cause and hopefully a solution. Thanks.
Phil
P.S. LG's wonderfully crafted manual has such nuggets of wisdom in its troubleshooting section as "Symptom: My DVD Player does not work. Possible Cause: There is no disc in the player. Insert a disc."
Some players allow playback of video files from memory cards/usb devices. The fact that you are getting the error while playing a normal DVD, would seem to indicate you have some sort of hardware issue/failure. Normal troubleshooting steps likely wouldn't apply in this case.
Ensure the memory card slot is free of debris/dirt and/or try leaving the unit unplugged for 30+ minutes to see if it will reset. Aside from that, you are likely looking at repair (if it's under warranty/maintainance contract) or replacement.Google is your Friend
How to view files on "empty" 16GB memory stick
By jimdagys in forum ComputerReplies: 15Last Post: 15th Dec 2011, 07:35 -
Vegas movie studio 10 "out of memory errors"
By magillagorilla in forum EditingReplies: 19Last Post: 25th Oct 2011, 10:58 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
Out of Memory Errors Re-Coding "WAR" for Backup
By Newminds in forum DVD RippingReplies: 1Last Post: 6th Jan 2008, 12:00 -
VCR Overscan Issues ("jittery" line at top of screen)
By jcm0320 in forum Capturing and VCRReplies: 14Last Post: 24th Aug 2007, 13:56
