"775 segmentation fault" is a very rare error. One hit on Google relating to Mac OS, being your post. It sounds like something out of a bootlog, not something in a regular error dialog box? Maybe you can provide more detail on what exactly happened?
Case, I got this instead in google:
Mencoder segmentation fault"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I took this from the Terminal output, since ffmpeg thinks the conversion was a success (it basically does not detect that mencoder has caused a seg fault) and creates an output file of zero length.Originally Posted by Case
I am trying to convert FLV to anything but it always seems to give this seg fault no matter what I try. I'm not a wiz at video codecs, I just want something that I can install that will work.
if you use perian, you can convert that flv file with QT or mpegstreamclip...
problems installing add'l software for ffmpegX: mencoder
By Tomtom2011 in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2010, 17:47 -
Segmentation fault while executing dvdauthor
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 17th Oct 2008, 18:33 -
Problems with ffmpegX 0.0.9y and mencoder on MacOSX
By anto1973 in forum ffmpegX general discussionReplies: 11Last Post: 16th Oct 2008, 00:42 -
[RESOLVED] ffmpegx 0.0.9y keeps asking for install of mencoder
By breggol in forum ffmpegX general discussionReplies: 1Last Post: 5th Oct 2008, 04:23 -
mencoder rotates, why not ffmpegX?
By PhilippeP in forum ffmpegX general discussionReplies: 1Last Post: 13th Apr 2008, 15:43
