I just started using AVSEdit, I looked at some tutorials and I tried to replicate what I've seen into my own script but every time I try to use any filters or anything I get an error message saying (This is after I clicked on 'external preview):
I think its something to do with my video, but I don't know how to fix it, anyone know?
Results 1 to 30 of 89
You haven't actually done anything in your script. Start reading some of the avisynth documentation at avisynth.org, including the sample scripts.
First, you need to load the video. You can try
DirectShowSource("pathtovideo")
or you can use DGIndex on your VOB file, then load the .d2v file it creates. That is a more complicated way to do it.Read my blog here.
Does the file play normally in a media player? (which one are you using)
Are you able to render the file normally without filters (using the loaded script)?
Please post your script here in text format (just copy&paste) -
The file only plays in WinDVD, it is a .VOB file at 4.46GB, it does not open with windows media player 11, because of this, I cannot preview my current work in it, so what do I use.
Here is my script:
# Created by AVSEdit
# Mateusz 04/03/2008
DirectShowSource("C:\Documents and Settings\Mateusz\My Documents\My Videos\Hairspray (2007).vob",25) -
I'm not sure what the ",25" argument is supposed to do, do you mean "fps=25"? Just take it out for now and see if it opens with virtualdub
Do you have a current version of avisynth installed? (i think 2.5.7)
You should be able to open your script in virtualdub or media player classic to preview if everything is working properly. If you cannot even playback normally in a media player, that suggests that you are probably missing a codec -
Not to discourage you from learning about avisynth, but VOB's and MPG's are usually handled better by using DGIndex to create a .d2v file and DGDecode_mpeg2source - as guns1inger suggested
What are you ultimately trying to do to your VOB?
The "crop" argument cuts pixels off each frame - are you trying to do that or did you really want to "trim" frames?
MPC comes with k-lite. Did you try opening the .avs with MPC or virtualdub? Did you check for avisynth version? Can you playback the VOB with MPC? -
I used DGIndex, I demuxed my video and remuxed it using ImagoMPEG-Muxer, I then used delay cut to sync the audio with the visuals but the video was terribly out of sync (I don't even understand why it was described as out of sync in the first place, looked perfect to me).
With my .VOB, I want to 'autocrop' the movie by removing the black bars on either side the video. I don't understand the difference between Trim and autocrop.
I have the latest AVIsynth version but the .VOB still doesn't play back with MPC or WMP11, only plays back using WinDVD. -
You want to crop off the sides, then do what with it ? You can't turn it back into a VOB without either resizing (and therefore distorting the image) or putting black bars back.
If you are happy to encode it as an avi file, then you would find virtualdubmpeg2 much easier to use for this exercise.Read my blog here.
Trim() selects ranges of frames. For example Trim(0, 100) selects frames 0 to 100 and ingores the rest of the video.
Crop() removes the edges of frames. Crop(2, 4, -6, -8) crops 2 lines off the top, 4 lines off the left, 6 lines off the right, and 8 lines off the bottom -
I just want to crop the .VOB, then convert it to H.264/AVC format so I can use it on the PSP.
LOL you should have mentioned this firstOriginally Posted by Nitro89
I strongly suggest ripbot264. It is super easy to use, automated, and has a PSP profile. It generates a script for you, and you can preview it, crop it, and resize it while viewing the preview. You can specify bitrates, some other options but it really it's just a few clicks.
Good luck -
Properties => Push the button "preview script" There are other cropping & resizing options when you push ">" to get to other menus
If you can't render it in MPC, or other media players, you probably need to clean up your codecs
Since you already have k-lite, use the codec tweak tool and check: detect broken codecs, broken directshow filters, register base directshow filters (quartz.dll), (the 1st 4 options)
If this doesn't work, uninstall & reinstall only the codecs that you need.
If that doesn't work, you may have to manually create a .d2v file and use DGDecode_mpeg2source (However, this script will only work if you can render with proper codecs in the first place)
If that doesn't work, this suggests that you have a problem with your VOB (corrupted perhaps) => try re-ripping your DVD -
I've never had to use that option, try it out, or ask the developer Atak_Snajpera on Doom9 - He visits and answers questions almost daily http://forum.doom9.org/showthread.php?t=127611
Was the audio delay there before encoding? -
so far, I have used DGIndex to demux the file, I then used Delaycut, chose 'fix' (don't know if that is the correct option you pick, if anyone knows, tell me), I then tried remuxing it using ImagoMPEG-Muxer, but the end product is still very out of sync, what aren't I doing properly?
Before muxing or using delaycut you can confirm the delay by opening the demuxed audio and video in Media Player Classic, and using the number pad + and - keys until you have it in sync. MPC - File -> Open File -> Open (video)/Dub (audio). Do this before delaycut to confirm the delay, and after delaycut to confirm the sync is now correct. If you then get sync problems after muxing, imago is at fault.
Read my blog here.
No, don't tick the "Fix" button. First find out the amount of the delay. guns1inger's method is one way. Fill in that same amount in the "Start" box of the "Delay" section of DelayCut. Leave everything else alone. Then "Process".Originally Posted by Nitro89
By the way, guns1inger, that method is a bit easier than the one I've been recommending which involves going Options->Audio Switcher and setting and then adjusting the delay in there. I've seen you mention this method a couple of times now, so thanks for the tip. -
I stop the video every time I change the audio, but nothing changes
MPC is my default player, and when testing out the method guns1inger described (holding down the + or - keys) it made very obvious on-the-fly changes in the audio synch. It even shows you the amount it's delaying the audio at the bottom of the screen. And one nice thing about it is after you close it the delay goes back to zero, unlike the other method where you have to set the delay back to zero, or else the next time you open a video that previous delay remains in effect.
One likely possibility is that there was a delay in the original VOB that you didn't take into account when remuxing. If you used DGIndex, then another possibility is that you decrypted incorrectly, not taking into account some new-fangled protection, which often sticks in bogus cells which can mess up the audio synch. If this is the Hairspray DVD still, it's infested with ARccOS which does that sort of thing. But it's still easy to fix if you have the AC3 track and use DelayCut to get rid of the delay.Why is the original VOB file in sync but when I demux it, and remux it, it goes way out of sync -
One note about MPC: I had to enable its internal audio switcher for the audio delay feature to work. View -> Options -> Internal Filter -> Audio Switcher -> Enable built in audio switcher...
Good find. When I opened mine to that place I found the box already checked. I don't remember checking it, but probably had to a long time ago to make the audio time shift box work. When I unchecked the box, hit "Apply", closed and then reopened MPC, I could no longer do the +/- thing. I apologize to Nitro89 for thinking he was doing something wrong.
It's possible I had turned it off at some point in the past. I'm using using 6.4.9.1.
AvsEdit 1.1.1.3 demands .NET Framework 1.1
By Leo48 in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2010, 03:10 -
AVSEdit 1.1.0.0 and Win 7 64 bit?
By Ron B in forum Video ConversionReplies: 2Last Post: 28th Aug 2010, 11:50 -
AvsEdit tool page
By loster in forum FeedbackReplies: 2Last Post: 11th Feb 2010, 04:33 -
AVSEdit filter question
By buddycat in forum Video ConversionReplies: 16Last Post: 17th Feb 2008, 10:07 -
I'd like to understand How to use avisynth/AvsEdit
By Hittz in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 21:25
