I converted a H.264 Stream from Premiere HD to a DVD.
SVCD2DVD took a while (about 2hrs) but finally created a folder with VOB-files. Whe playing the VOB-Files it looks like a Charlie Chaplin movie, colour and audio is fine - but movement of persons and objects is on a very low framerate...looks like 5 frames per second or so - as I said: like a Charlie Chaplin movie...
Does anybody know what the problem is?
svcd2dvdlog-20080303000405.txt
Post your log file.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Have you tried playing any other way than just directly from the VOB files? Use a software player or better yet burn to an RW disc and try in a stand alone player.
If the problem is still there, try running the TS file through VideoReDo quickstream fix:
https://forum.videohelp.com/viewtopic.php?p=1390719#1390719
and make sure:
https://forum.videohelp.com/viewtopic.php?p=1391460#1391460Dwight
- Herm Albright
It is because of the type of interlacing in the h264 stream. If you drop me an email i can give you a different build to test to see if this can be resolved.
Thanks CB. I wondered about that but I with my limited knowledge of the inner workings of S2D I wasn't sure.
Dwight
- Herm Albright
Converting H.264 RTP Video to MPEG-2 Transport Stream
By trekgeek in forum Video ConversionReplies: 0Last Post: 20th Feb 2011, 09:24 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
RAW blu-ray 264 video stream to MP4 ? Problem
By scoobdriver in forum Blu-ray RippingReplies: 7Last Post: 18th Nov 2008, 18:19 -
Problem when converting to High Quality framerate
By hzgg2 in forum EditingReplies: 3Last Post: 30th Aug 2008, 17:14 -
converting framerate problem
By Shaorin in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 00:00
