I am still having a problem with my Toshiba HD-A3. When I press
stop on the remote and then play again. It starts from the begining
of the movie.
If I press pause and leave it on Pause too long it will not play again when
I press Play.
The only solution I have found so far is to press Menu, menu pops up and
press Pause that way. Then press play again and it will start to play where
it was. Makes me miss my OPPO.
My current Firmware Version says under Maintenance 1.3/1.1
Is there new firmware out there that I have missed or does anyone
know how to solve this problem. I also have the screen saver set to off.
It is hooked up to my Samsung 46" DLP HDTV . Via HDMI
Any Help would be Great Thanks Again..
That is a known "issue" with the players. I don't believe it has been "fixed".
Google is your Friend
Problem recording with Toshiba D-RW2
By polesel31 in forum DVD & Blu-ray RecordersReplies: 22Last Post: 10th Sep 2011, 21:44 -
Toshiba SD190 hack problem
By elaine1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jan 2010, 12:00 -
Toshiba HD-02 problem
By kangarew113 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 18th Jan 2008, 09:14 -
Problem with Toshiba AC adapter
By jyeh74 in forum Off topicReplies: 4Last Post: 14th Jan 2008, 11:37 -
Problem with my Toshiba XS-34
By gymnastgirl in forum Capturing and VCRReplies: 5Last Post: 10th Aug 2007, 22:55
