i have a dvd movie in .iso format im trying to open in dvdshrink but i keep getting a error saying that it cant read the iso
i took the files out of the iso and ran it threw fixVTS and it will open but when i try to make an iso in dvdshrink with the fixed files it works till i try to open the new iso in dvdshrink then i get the same error how can i make a iso out of this dvd but keep it so it works with dvdshrink?
sorry for my bad Punctuation but im a dropout lol
Results 1 to 16 of 16
I'm assuming that ISO image is bigger 4.3gb so you wanna shrink it down to fit a single layer dvd disc. Use the files you created w/fixvts and just create a VIDEO_TS folder from DVD SHRINK then you can still burn it with IMGBURN. IMGBURN can burn VIDEO_TS folders.
the iso is 4.32gb and i know i can burn VIDEO_TS folders
but i am not burning it, i am trying to make a iso that will open in dvdshrink and not get errors. there has to be a way to make an iso so dvdshrink will open it if it will play files from a video_ts folder as long as they are fixed with fixVTS
is there anyway for me to make an iso so dvdshrink will open it
i have about 12 other isos that came is the same format with the .mds file and most them play but there is like 3 that i get an error on in dvdshrink
i deleted the .mds files for them but that shouldnt mess it up so it dont open in dvdshrink so i dont get y they will not open. can someone help me out with this -
2 suggestions,
1: to open an iso in dvd shrink you have to use the file/open disc image option and point to the place of the iso wether it be on the hard drive or on a disc.
2; Reinstall dvd shrink as I have known it get corrupted.
http://www.softpedia.com/progDownload/DVD-Shrink-Download-4128.htmlPAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
i know how to open an iso in dvdshrink lol i get an error on a few of my movies but when i take the movies out of the iso and run it in fixVTS it will work and i can open it in dvdshrink but then when i make a iso again out of the fixed files in dvdshrink i get the errors again but i dont get y only iso format for these movies and my dvdshrink is not corrupted
Okay well you can use the VIDEO_TS folders and use IMG TOOL CLASSIC to create a iso image.Originally Posted by zookeeper525
http://www.coujo.de/ib2/index.php?act=module&module=include&incl_name=download
scroll down that download page I posted up above and download ImgTool Classic 0.91.7
you should be able to create a iso image from that VIDEO_TS folder. then try opening it up with DVD SHRINK. Are you using the last version of DVD SHRINK? You may wanna try downloading version DVDShrink 3.2 it from the link below.
http://www.mrbass.org/dvdshrink/
or you can download a older version like DVDShrink3.0B5 from here:
http://www.mrbass.org/dvdshrink/dvdshrinkold/ -
i just get errors trying 2 make a iso with that something about the ifo file is bad or i found a mkisofs bug
UPDATE> i just tried opening the VIDEO_TS folder in dvdshrink without running it in fixVTS and it open with no prob so y is it that only the iso ver on these movies messing up i dont understand -
im not that good i never used pgcedit and how and can i fix a malformed movie? or are the movies recked. i hope they are not unfixable because i dont have the dvd anymore all i have is the img files of the movies
but y is it only messed up for trying to make an img but you can open the reg VIDEO_TS folder in dvdshrink but not any img/iso of the movies i dont get it lol -
i'm not really sure why, that is strange.. but if you output from shrink to file format, you can then open the files with pgcedit. chances are, it will automatically alert you to any problems and offer to correct them. then you simply save the file and burn it. one thing though, the original files will be included in a backup folder, so you may want to delete these before burning.
I am just a worthless liar,
I am just an imbecil -
ok loaded the VIDEO_TS in pgcedit and it got alot of alerts when i first open it but idk what i did lol but i made a img with imgburn and now it opened in dvdshrink
thanks alot for your help toolfool now to try 2 fix the other movies i have lol
but for the video_ts folder do i just leave the dvd navigation files in it? -
good deal! pgcedit automatically fixed whatever the problem was.
those backup files are created when you first open the dvd with pgcedit. they are there so you can restore the files to thier original (in case you mess it up). as long as your new files open ok, you can safely delete all those backups.I am just a worthless liar,
ok thanks alot for your help ToolFool you just saved 4 of my old 007 movies lol
glad to help
trouble with fab
By slayer_of_all in forum Blu-ray RippingReplies: 2Last Post: 24th Mar 2011, 13:44 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
Trouble with OE
By alegator in forum ComputerReplies: 4Last Post: 6th Feb 2009, 14:52 -
AVG trouble
By romanstopme in forum ComputerReplies: 2Last Post: 31st Dec 2008, 11:45 -
PS/2 Trouble
By gooberguy in forum ComputerReplies: 22Last Post: 19th Jun 2008, 18:08
