Some of my Final Cut "friends" decided it would be a good idea to send me .mov video files in DVCPro 50 and I need to get them into Premiere without spending any money. Any ideas?
Which version Premiere? DVCPro25 is essentially the same at the digital firewire stream level as consumer DV format or DVCAM. Ask how these files differ if at all from *.DV under Quicktime. It should be the same thing.Originally Posted by LuckieGW
DVCPro50 (4:2:2) is usually decompressed to an uncompressed SMPTE 259M SDI transfer and edited uncompressed.
see http://en.wikipedia.org/wiki/SMPTE_259M
I'm unaware as to how DVCPro50 is handled by Quicktime under Premiere other than as an uncompressed stream.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'm using Premiere CS3.
I can't get DVCPro50 to play in Quicktime, VLC Player, MplayerClassic, or imported in Premiere. The file is HD (1440x1080). I thought it would have to be DVCProHD but in every file properties box I look at, it shows up as DVCPro50.
Premiere throws an error when importing stating that it does not have the codec. I've played the file on a Mac but it refuses to play on Windows. -
My experience with DVCPro50 is limited to its definition as a tape format and output from the machine as SDI for uncompressed editing. So all I can do is point you.Originally Posted by LuckieGW
Mainconcept has a transcoding codec for DVCPro25/50. I assume digital format specification for DVCPro50 has resulted from the P2 card and MXF container format.
http://www.mainconcept.com/site/consumer-products-4/dvcpro-2550-20274/information-20294.html
http://en.wikipedia.org/wiki/Panasonic_AG-HVX200
http://en.wikipedia.org/wiki/MXF
Best places to ask are in FCP or Premiere CS3 forums. Or call Adobe and/or Panasonic support Monday morning.
CS3 has no direct support for DVCPro50
http://www.adobe.com/products/premiere/supportedformats.html
I've never dealt directly with SMPTE 314M which defines DVCPro25/50 as a data structure.
http://www.digitalpreservation.gov/formats/fdd/fdd000183.shtmlRecommends: Kiva.org - Loans that change lives.
denoise clips before importing in premiere
By codemaster in forum EditingReplies: 0Last Post: 27th Apr 2012, 17:13 -
Importing MPEG-2 videos on Premiere Pro on OS X Lion
By Atoon in forum MacReplies: 1Last Post: 1st Feb 2012, 04:08 -
Premiere importing mts files problem
By marinteshvara in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2011, 19:28 -
After Effects to Premiere... importing problems?
By Saibot in forum EditingReplies: 1Last Post: 21st Feb 2009, 23:48 -
Importing AC3 into Premiere Pro ?
By Zetti in forum EditingReplies: 14Last Post: 23rd Jan 2009, 01:45
