I have a SONY TVR 330 Video Cam fitted with a widescreen lens. I tried to film an event using the widescreen option in the videocam and also using the widescreen lens but when i began to convert the film into VCD or other formats, the video was not in a widescreen. The video was instead in a normal screen format with a video of my fat brother looking quite slim.
Why is this?? :( :(
I don't know what software you use but I think you should check your options before encoding to VCD. For example: did you use the option "keep aspect ratio"? I think you should try that...
I have the same problem with my DV cam. The solution is NOT to keep aspect ratio settings when encoding, because it just looks like 4:3 format. When encoding in TMPGENC you can specify the settings for the ratio. You choose "Custon settings" and calculate the settings. My guess is that if your original 4:3 video is 720x576, you should choose 720x405 to get the black bars you need (It should still remain 720x576 in the output settings).
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 12:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15
