i bought TRANSFORMERS on HDdvd yesterdayt - and now i try to convert it to BLURAY via the great guide on "doom9". But when i have evodemuxed the file and wants to get the audio out with EAC3to - i get an "error" message... the guide says to "rename" the audio.mpa to audio.dd+ , but when i do that the file STILL is a .mpa file even though i clicked on it and "renamed" it audio.dd+
It seems like the file just gets the name : audio.dd+.mpa - i mean , it doesn't change the filetype - and therefor the EAC3to program can't find the file...
Anyone else ever had the same problem ???
You probably should ask at Doom9 as very few of us here even attempt to do this kind of thing. If you did ask at Doom9 and no one helped you, I'm sorry, but that's how it is at Doom9 sometimes. You might wait a month and post again (I've done that before at Doom9) and you might get help then. A few years ago I posted a technical question and nobody responded and then about 1 month later I posted it again and got some good help.
MPEG Audio is legal for HD DVD. I was loaned a copy of The Transformers on HD DVD by a co-worker. I no longer have it and I have no way to rip it. I can tell you though that this copy (sold in the USA) definitely did not have MPEG audio on it. Whether or not your copy actually MPEG audio or there is some weird problem with EAC3to, I can't say, but it is theoretically possible to have MPEG audio on HD DVD. -
Moving you to our NEW blu-ray/hd-dvd ripping forum.
It doesn't matter what you call the file.Originally Posted by kulmagen
When you demux the audio, call it input.ac3
then, start>cmd and navigate to your eac3to folder and then type, eac3to "X:\source directory\input.ac3" "X:\destination directory\audio.ac3" -libav -640
This gets you a useable ac3 file that will be accepted by most software.
If you're still having problems, did you apply the dump file?Regards,
Rob
EAC3TO X to AAC
By 8xprbhf in forum AudioReplies: 0Last Post: 11th Nov 2010, 11:12 -
eac3to
By MURPH99 in forum Video ConversionReplies: 3Last Post: 27th May 2010, 09:48 -
EAC3TO error
By soadtrails in forum Video ConversionReplies: 0Last Post: 28th Feb 2010, 19:31 -
Eac3to
By Bazza-61 in forum AudioReplies: 3Last Post: 23rd Sep 2009, 20:05 -
Question with eac3to
By ultraman36 in forum AudioReplies: 0Last Post: 11th Dec 2007, 17:44
