Hey guys,
I got a problem with AutoGK. I want to convert a DVD iso to an AVI file in order to convert it to a DVD again to include the correct subtitles. (Ok, there might be an easier way to do it). Anyways, I put my DVD iso in DEAMON tools and start up AutoGK. For the input field I select the VIDEO_TS.IFO file and select track 1. I make my settings as I think would be best for me and add the job to the list. However, the "start" button keeps being greyed out, so I can't click it. I can't find why it's greyed out, I can't find it in the AutoGK manual and FAQ. Can one of you guys perhaps help me out?
Screenshot
Thanks in advance,
Purno
Have you installed Divx Codec or Koepis Xvid Codec?
Have you read a guide http://www.divx-digest.com/articles/autogk.html ?
Or use another method where you don't have to reconvert the video, see https://forum.videohelp.com/topic338721.html -
I have now, thanks.Originally Posted by Baldrick
I didn't read this particular guide. I did now, but it didn't really explain much new. Though, it seems now I have pressed the "Abort" button, the "Start" button becomes available. So I guess the problem is fixed.Have you read a guide http://www.divx-digest.com/articles/autogk.html ?
Hmm... looks quite complicated for me, besides, it seems I'd have to install a bunch of new tools again, and my hard disk already is messy. I'll first try it with converting, if that doesn't give a satisfying result, I'll try this.Or use another method where you don't have to reconvert the video, see https://forum.videohelp.com/topic338721.html
Thanks a lot!
It's not that complicated if you use subtitle creator and use its wizard. But Autogk works also.
*sigh* Another issue - "force mono" missing in AutoGK.
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 15th Apr 2013, 19:32 -
TMPGenc Authoring Works 4 - How do I set the "first button" on a menu?
By silentmachine in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2011, 07:05 -
How to solve "yv12 height must be multiple of 4" problem in autogk?
By vampypiano in forum Video ConversionReplies: 0Last Post: 29th Jan 2011, 01:20 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 13:46 -
"Filters" greyed out in VDubmod
By Captain Satellite in forum Newbie / General discussionsReplies: 5Last Post: 16th Aug 2007, 11:39
