  1. Can anyone help me isolate this problem please? I use CamStudio 2.00 for screen captures. In the past I've accepted the default codec, 'CamStudio Lossless Codec v 1.00' without thinking much about it. I've tried DivX a few times, but the quality after import into my editors (Magix MEP, Womble) and rendering to DVD MPEG was rather poor. Recently I installed a new codec, based on the following advice (can't find the origin right now):
    "Use the MSU Screen Capture Lossless Codec as it creates smaller files than the Techsmith Screen Capture Codec http://www.compression.ru/video/ls-codec/screen_capture_codec_en.html
    But after using this in Video Options|Compressor, I get the following behaviour:
    - The immediate playback in CamStudio is corrupted (many coloured stripes)
    - Same result when I play it after importing to Magix MEP.
    - Yet it plays fine in VirtualDub. File|Information reports:
    Frame size, fps (us per frame) 1044x662, 25.000 fps (40000 uS)
    Length: 178 frames (0:07.12)
    Decompressor: MSU Screen Capture Lossless Code
    Number of key frames:
    Min/avg/max/total key frame size: 1267172/1267752/1268333 (2477K)
    Min/avg/max/total delta frame size: 0/173/7994 (30K)
    Data rate: 2883 kbps (0.17% overhead)
    - If (without understanding) I use Gspot 'Proposed Codec Solutions and Tests', steps 1 & 2, I get the following report, unintelligible to me:
    (Src)-->>--(A)-->[Avi Splitter ]>--(B)-->[VFW:MSU Screen Capture Lossless Codec v1.2 ]>--(C)-->[Video Renderer ]
    Failed to create instance of Avi Splitter. CoCreateInstance() failed. Error: 0x80040154: [unknown]
    (Src)-->>--(A)-->[DivX Demux ]>--(B)-->[VFW:MSU Screen Capture Lossless Codec v1.2 ]>--(C)-->[Video Renderer ]
    Failed to connect Output pin 0x0658419c ("Src Media") on Prague1-MSU.avi to input pin 0x065913b4 ("Stream") on filter 0x03eb6f6d ("DivX Demux").ConnectDirect() failed. Error: 0x80040207: [unknown]
    (Src)-->>--(A)-->[AVI Splitter ]>--(B)-->[VFW:MSU Screen Capture Lossless Codec v1.2 ]>--(C)-->[Video Renderer ]
    Video Render OK. Use [3] to play.
    Here's what Gspot reports:
    --- File Information ---
    File Name: Prague1-MSU.avi
    File Name (with full path): D:\Movies\Camstudio\Prague1-MSU.avi
    File Size (in bytes): 2,572,800
    --- Container Information ---
    Base Type (e.g "AVI"): AVI(.AVI)
    Subtype (e.g "OpenDML"): AVI v1.0,
    Interleave (in ms):
    Preload (in ms):
    Audio alignment("split across interleaves"):
    Total System Bitrate (kbps): 0
    Bytes Missing (if any):
    Number of Audio Streams:
    --- Video Information ---
    Video Codec Type(e.g. "DIV3"): SCLS
    Video Codec Name(e.g. "DivX 3, Low-Motion"): <unknown>
    Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are Installed
    Duration (hh:mms): 0:07.120
    Frame Count: 178
    Frame Width (pixels): 1044
    Frame Height (pixels): 662
    Storage Aspect Ratio("SAR")" 1.577
    Pixel Aspect Ratio ("PAR"): 1.000
    Display Aspect Ratio ("DAR"): 1.577
    Fields Per Second:
    Frames Per Second: 25.000
    Pics Per Second: 25.000
    Video Bitrate (kbps): 2883
    MPEG-4 ("MPEG-4" or ""):
    B-VOP ("B-VOP" or ""):
    QPel ("QPel" or ""):
    GMC ("GMC" or ""):
    NVOP ("NVOP" or ""):
    H264 ("H264" or ""):
    Quality Factor (bits/pixel)/frame: 0.167"
    Any advice would be appreciated please.
    Terry, East Grinstead, UK
  2. Pleased to report this was promptly sorted by Magix.
